Old 02-22-2009, 06:18 AM
Postkill Postkill is offline
Default How do I change Tempo's throughtout a song in PT 8?
How do I change tempo throughout a song in Pro Tools 8?
I am working on some songs and I want it to slow down and then pick back up in the middle of the song.
Hope someone can help?
Thanks,
Craig
Old 02-22-2009, 07:22 AM
Default Re: How do I change Tempo's throughtout a song in PT 8?
check out the section in the manual for the tempo editor, beatiful part of the screen you can draw your tempo in or edit it like volume automation in tracks, or type in the bpm you want for "this" many bars. many ways to do it.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 02-28-2009, 08:14 AM
Ok kewl thanks will check it out.
Off to do PT 101 next weekend so hope to cover it then.
Thanks!
Old 12-28-2010, 08:18 AM
Save|The|Architect Save|The|Architect is offline
I am having an issue with tempo automation. I can only edit the ENTIRE tempo faster or slower.
It highlights the section to be changed , but when I drag up or down that highlighted section, the entire part moves. Have you got a solution to this?!
Also, the pencil tool is faded out when I try and mark in the point of change manually, it only works in the multi tool!
Cheers!
- Running Pro Tools LE 10.0.0.
- MBox 2.
- Mac Pro Tower, 2.8 GHz.
- 2 x Quad Core Intel Xeon.
- 1 TB Space.
- 8GB RAM.
- Oxygen61 Key USB MIDI Controller.
- Korg R3 37key MIDI Controller.
- MacBook Pro
- 8 GB
- 8 Cores
-1 TB Disk space
Save | The | Architect
www.savethearchitect.com
Old 04-21-2011, 08:08 PM
Matt Rushmore Matt Rushmore is offline
Just went through this issue so even though this thread is old I'm adding my resolution to the faded out pencil problem for others to find in the future.
Even though the manual I have doesn't appear to say this (that I could find anyway), make sure the conductor button on the transport window is activated and then you can insert tempo events like the manual describes (and the pencil will look normal too).
Matt Rushmore
ASUS P6X58D-E / i7 950 / 12gb 12800 HyperX DDR3 / GeForce ASUS EN210 Silent 512mb / (2) WD Caviar Blue 500GB SATA 16mb 6.0Gbs / Windows 7 64 Bit / 003R / PT9.0.2
www.reverbnation.com/jmaccadillac
Old 04-29-2011, 10:54 AM
CherylD CherylD is offline
I am having the same issue. I have recorded the song, but it just feels like it's dragging. I want to increase the entire tempo, but when I change, only the drum track changes. So someone told me to make sure everything is in ticks and not samples, but this didn't make a difference. Any help would be awesome.
Old 04-30-2011, 12:44 PM
mykhal c's Avatar
mykhal c mykhal c is offline
havin' all your trax in 'ticks' mode should allow your session to follow your tempo changes for the session. so if you change the tempo at the conductor or if you have it manually set, the session should follow as long as your trax are in ticks mode. not sure why that's not workin' for you
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 05-01-2011, 06:23 PM
misterdmz misterdmz is offline
You can also automate tempo from the dropdown tempo menu as seen here:
http://www.youtube.com/watch?v=yJQbtOupnh8
Old 05-01-2011, 07:00 PM
robo6675 robo6675 is offline
Default
Putting your tracks into tick based is correct but that'll only effect midi unless your audio tracks have elastic audio enabled. Hope that helps.
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod
Terrarium
HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2
(3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console
Old 05-01-2011, 11:15 PM
mykhal c's Avatar
yep...a VERY important step i omitted. isn't this on by default in PT8? cannot remember...
Song Key Change shultzee13 Tips & Tricks 10 06-25-2009 01:36 PM
tempo change of song? Roy Stanton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-14-2008 02:43 PM
Matching Up Tempo's -- Like Acid 6.0 Pro Kbone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-12-2006 01:38 PM
How to change tempo mid-song? MinhSomeLoseSome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-19-2003 05:33 PM
Change the length of a song. davedog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-15-2000 12:19 AM
