Rosetta 200 cables going to 002 question
Hello,
I just purchased a Rosetta 200 and it will be coming in a couple of days. I wanted to purchase the cables that would be necessary to connect the Rosetta 200 to my Digi002. My head started twisting after reading SPDIF, Toslink, etc... I believe I need a TOSLINK on one end to an optical SPDIF on the other. Could somebody post a link to a store that sells the cables that I need. Just so I have an idea of what exactly I am looking for. I know I am going from my optical out to Rosetta back to my optical in...I believe! Thanks guys, k |
Re: Rosetta 200 cables going to 002 question
The easiest way to connect a Rosetta 200 to a 002 is via S/PDIF. If it's a short run, a standard RCA-to-RCA cable will work. Just like you use to plug a CD player into your home stereo. Yes, you can buy a S/PDIF cable, but for a short run it's not going to make any difference. It's cheaper than buying optical cables, plus it leaves your 002 optical port open in case you want to add an 8-channel converter later, like a Rosetta 800.
Joshua L. Decatur, AL |
What he said but you should get an RCA-RCA video cable instead. It is important that it be 75ohms for s/pdif which audio cables aren't necessarily.
Tom Lynn my music: www.tomlynnmusic.com other people's music: www.headphonomenon.com |
Thanks guys! perfect..
Reamp cables, question | FSM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-28-2009 05:09 AM |
Quick question about BNC Cables | legasafe | Post - Surround - Video | 4 | 05-12-2008 05:56 PM |
Question regarding cables. | rx2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-09-2003 01:34 PM |
gear question, cables. | jon sutton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 07-10-2002 12:13 AM |
C24 D Sub Cables Question | Studio 5109 | ICON & C|24 | 1 | 07-20-2001 12:43 AM |
