plug-in tremolo ??
Hello all,
Does anyone out there know of a good plug that will produce a good tremolo effect for either electric or acoustic guitar?? I have the Waves NGB on my Mac by have not come up with anything satisfying. TIA. Tony
___________________________________________ Mac Pro 2010 2 x 2.66 / 40GB RAM / OSX 10.13.6 / PT2020.5 / Metric Halo ULN-8 |
Re: plug-in tremolo ??
Crowdog-
Use the Mondomod plugin, but turn everything off but the Amplitude Modualtion (this is tremolo). From there, you can adjust rate and depth...should do the trick. That one plugin is pretty interesting because it is 4 or 5 plugins in 1. Phase, flange, chorus, tremolo, vibrato, auto-pan, etc.
It's not rocket surgery |
Hey Chris,
Thanks for tip! I will try this ASAP. Merry X-mas Tony
Crowdog...
As a follow to my last post, I just wanted to give you a few more specifics about the Mondomod-as-tremolo: Make sure you've got the Mix setting set to 100 (all effected sound, no direct). You can also choose what kind of waveform you'd like (sine/square/triangle/saw/backwards saw). To really utilize this plugin (and most Waves plugs), you've got to understand the principles behind them (modulation in general for the Mondomod)...the Waves manuals do an excellent job of explaining all facets of the plugins and why they are the way they are.
Chris ,
After your 1st post I got off my butt & RTFM it was one of the few of many that i didn't read in it's entirety. It explained the AM vs FM thing very well , and it works great! Once again thanks for your help! Happy Holidays, Tony
Plug-in for tremolo effect? | crowdog | Tips & Tricks | 16 | 04-22-2021 02:03 PM |
Recommend me a tremolo plug in! | Michael P. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-21-2008 01:36 PM |
Tremolo plug-in | Naagzh | Tips & Tricks | 0 | 06-19-2004 11:32 PM |
Tremolo plugins | taiazeez | Pro Tools TDM Systems (Mac) | 9 | 02-21-2003 08:58 AM |
Tremolo FX for Fender Rhodes | Nelson Leeroy | Tips & Tricks | 6 | 11-05-2002 02:03 AM |
