Hard to Close Playback Engine Window
Hi, I just updated to Pro Tools 2022.7.0 & when I open up Playback Engine, there is no "OK" button to close it. Does anyone have any suggestions? I attached a screen shot.
Thanks so much, David
https://adornment.bandcamp.com/ https://andotherwonders.bandcamp.com/ http://gcsband.bandcamp.com Mac Mini (m1, 2020)// OS Monterey// Clarett +2Pre// Pro Tools Studio 2023.6.0 |
Re: Hard to Close Playback Engine Window
You trashed prefs? Always start there. See "help us help you" up the top of each DUC web page. Use Pete Gates PT Prefs utility to make that easy.
You can also try creating a new admin account and test from there. A suspect cause is you may have got display scaling set to something that helps push the [OK] Button off the bottom of that screen. Play with the Display scaling in macOS preferences. Still stuck provide the exact display model/screen resolution and scaling settings being used where this happens. |
Maybe the 'enter' key works, even if you can't see the OK button.
Strange thing, I've never seen that before, or anything like it, and I've used PT with macs for 20+ yrs, across many displays, resolutions etc. My guess is this is PT. I have a hunch; all the different bug reports we're hearing about on the last few dot updates are because of the code being changed/prepared for apple silicon native, under the hood so to speak. But what do I know.
Thanks so much, Darryl & Ben! Pushing 'enter' worked! :)
Are you still not seeing the OK button?
Still not seeing the 'OK' button.
Side note, lost Falcon with the upgrade so trying to see if I can get an older version that will work with my MAC OS.
But I think it's best you create another thread about your Falcon problem, if you need to.
N key won't open Playback Engine window | Firewalker | Pro Tools 12 | 7 | 12-18-2017 12:52 AM |
Video Engine Playback Window Not Working | jdgiese19 | Pro Tools 12 | 3 | 12-19-2016 01:15 PM |
External Hard Drive as Playback Engine | arturoinletto | Pro Tools 11 | 3 | 07-08-2014 05:58 PM |
When I pick adc in playback engine it wants to close my project | Raoul23 | Pro Tools 9 | 2 | 11-23-2010 11:10 AM |
something new in playback engine window | x9blade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-26-2005 09:56 PM |
