Old 07-01-2007, 10:30 PM
hobing hobing is offline
Default HD and LE/M-powered on same computer
Is it possible to install PT HD and LE/M-powered on the same system?
I've been a user of protools since 1999, from Digi 001 to M-Powered systems (owning several interfaces). Working constantly in studios with TDM systems, I've decided to upgrade myself to HD2.
I might need to go back to my M-powered system once in a while so would like to keep the software installed. Is there anything that would prevent such a setup?
The system is still in boxes, since I was on some important project and would not risk installing something new. I'm ready to install it soon, and would try to find out if this kind of configuration is possible
Many Thanks
Old 07-01-2007, 10:39 PM
sunburst79 sunburst79 is offline
Default Re: HD and LE/M-powered on same computer
It can be done, I beleive Rails done it.
Somewhere there ia a step by step guide from Digi on installing multible versions of PT. As I recall you have to install it and then move the DAE file to your desktop. Install the new program and the drag the other DAE file back into the folder. Something like that.
But yes it can be done as long as the respective hardware is hooked up.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 07-02-2007, 12:59 PM
Brushfire Brushfire is offline
It can be done, I believe Rails done it.
Somewhere there ia a step by step guide from Digi on installing multiple versions of PT. As I recall you have to install it and then move the DAE file to your desktop. Install the new program and the drag the other DAE file back into the folder. Something like that.
I had the same question. I'm switching over to an HD system and would like to keep my 002R as a backup after reading some of the other recent problems with HD. I tried a search on "Rails" and no one with that name came up. Tried a search on "installing multiple versions of Pro Tools" and no luck.
Tried searching Digidesign too, no luck...
2 GHz G5 Dual Core Mac with 2GB RAM OS 10.4.8 Pro Tools 7.3.1cs8 Separate internal audio drive 23" Mac monitor Pro Tools HD 3 Accel (PCI 1 Core Card, 2 Accel Cards) MassivePack Pro 4 Digidesign PRE (2) 192 I/Os w/192AD Expansion cards Magma PE6R4 6 Slot PCIe to PCI-X Expansion Chassis
Old 07-02-2007, 08:39 PM
Rail Jon Rogut (spelling?)
I couldn't find the link either. It can be done though.
Scott
Core 2 Specs Page
Old 07-02-2007, 09:44 PM
Andre Knecht Andre Knecht is offline
Search the TDM forum for topics (not contents) containing the “LE” and you are bound to land on a valid thread. This is one that pops up something like every three weeks.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 07-02-2007, 11:50 PM
wmcintyre wmcintyre is offline
Here's the link
Can you run HD and M-Powered simultaneously on the same computer? Zep Dude Pro Tools TDM Systems (Mac) 5 09-08-2008 12:42 PM
7.4.2pr LE and M-Powered on same computer? byronfunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-22-2008 01:39 PM
LE and M-Powered on the same computer? gpond99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-08-2007 12:59 PM
M-powered computer advice... petter Pro Tools M-Powered (Win) 5 10-25-2006 08:27 PM
Which computer is better for m-powered? sethbrand Pro Tools M-Powered (Win) 3 03-22-2006 08:36 AM
