How To Turn NAP Off (What they don\'t tell you)
Ya gotta love the user friendly twidgets of Digi! But what do you expect, they haven't updated the General Troubleshooting since 2003... To turn off NAP what they DON'T tell you in the General Troubleshooting section for PT 6 & 7 is that after downloading the NAP app you unstuff it with stuffit. Move the unstuffed napsetting app to your applications folder. Then open the napsetting app with ScriptEditor and change =1 to =0 in the script to change the command to not allow NAP on reboot. Then click "save" so it saves the changed application. Do not save it as a script, it has to remain an application. Then open System Preferences > Accounts > Login Items and drag the changed app into the login items window.
2 GHz G5 Dual Core Mac with 2GB RAM OS 10.4.8 Pro Tools 7.3.1cs8 Separate internal audio drive 23" Mac monitor Pro Tools HD 3 Accel (PCI 1 Core Card, 2 Accel Cards) MassivePack Pro 4 Digidesign PRE (2) 192 I/Os w/192AD Expansion cards Magma PE6R4 6 Slot PCIe to PCI-X Expansion Chassis |
Re: How To Turn NAP Off (What they don\'t tell you)
Thanks so much for posting that, Brush. I've always wondered why that damn NAP was still on after all that yin-yang...aye. Good lookin' out good brother. -Eric @ Studio Curve Dominant |
Please explain what NAP is and how it helps to have it turned off. I searched the forum and just found a question about how to turn it off, but it did not explain what it is.
Thank you.
No rules...just good. |
Apparently, it can also induce system crashes if enabled while DAW systems are in use. It can also cause the computer to emit a whining sound - which I've noticed is now conspicuously absent from my G4, now that I've implimented Brushfire's NAP ScriptEdit fix (yes, it worked). The DUC should consider making this thread a sticky, OR, addending the Troubleshooting page to include this new info. I've been experiencing some weird system crashes while running the MBox system, and it will be interesting to see if those crashes desist, now that I've got the NAP setting to switch off. I will keep us posted in that regard. -Eric Vincent @ Studio Curve Dominant |
Can't turn off Mac Function keys/turn on PTLE Shortcut keys | b mcgibney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-25-2009 09:15 PM |
How to turn off pop up help?! | woof | Pro Tools TDM Systems (Mac) | 2 | 04-22-2008 07:37 AM |
to turn off 002 or not to turn off 002? that is the question | andy1908 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-07-2007 10:47 AM |
If my Mac DOESN'T TURN OFF ?? | hed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-08-2005 11:40 PM |
