Audio Input Distortion Even Under 0 Db
I have a Digi 002 Rack, G5 dual core mac, OS 10.4.8, 2 GB RAM, PT 7.3.1 with the Pro Tools LE 7.3.1cs2 for Mac OS X update.
Yesterday while recording a miked acoustic guitar, I noticed that the signal in the headphones was distorting/clipping. This reminded me somewhat of the earlier problems with 7.3 when it first came out. I trashed the preferences and databases twice already and the problem still exists. If I turn the gain up on the 002 input to try and get the input signal loud enough without clipping, any setting of the gain knob higher than 12 O'Clock seems to start generating the distortion. At 12 O'Clock the green audio track indicator isn't even halfway to the clipping stage. It also seems to be dependent on where the input fader is set too. Fader settings just below 0 Db is where it starts and it gets worse as the fader is set higher. This never used to happen before. I used to be able to push the fader on a vocal or other instrument above 0 Db so the singer/player could hear it better, but now it has this digital distortion. I didn't do anything different with my mic setup and I'm using the 002 phantom power like I have always done. I set up a stereo track for our FP-8 piano and the same thing happens. The output volume on the FP-8 is set to 8 which is where I've been recording it for years with no problems. Now it distorts. I also noticed that when my wife played the FP-8 while testing, the master fader didn't show a signal at all. I have no plug-ins inserted in either the recording track or the master fader so all the audio coming through and out is unprocessed. I still have my old 001 and at first I thought the mic and/or the headphones or headphones amp may be the problem. I changed the audio cable connected to my headphone amp and it was still distorted. I direct connected my headphones into the 002 it still distorted. I connected the mic and the headphones to the 001 upstairs and the signal was fine. Software bug? Am I going to have to go through the agony of re-installing the software?
2 GHz G5 Dual Core Mac with 2GB RAM OS 10.4.8 Pro Tools 7.3.1cs8 Separate internal audio drive 23" Mac monitor Pro Tools HD 3 Accel (PCI 1 Core Card, 2 Accel Cards) MassivePack Pro 4 Digidesign PRE (2) 192 I/Os w/192AD Expansion cards Magma PE6R4 6 Slot PCIe to PCI-X Expansion Chassis |
Re: Audio Input Distortion Even Under 0 Db
Additional information:
The distortion doesn't seem to be appearing in playback, so maybe it's a software issue regarding headroom of the digital audio signal while recording and monitoring?
003, Input Distortion | meanie2188 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-03-2011 09:04 AM |
Input Distortion | dkrametz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-01-2010 09:03 AM |
Digi 002 input distortion | COTRMedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-14-2005 07:53 AM |
002 Alt input--unwanted distortion | cii33 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-02-2003 12:05 PM |
Input distortion problems | Bob Zelin | ICON & C|24 | 8 | 02-19-2003 02:58 AM |
