Old 10-10-2004, 04:02 PM
matts9383 matts9383 is offline
Default 15\" Powerbook test results
I was wondering if anyone had any performance notes on the newest 15" powerbooks. I'm looking into replacing my setup (DP G4) with a more mobile setup, but don't want to get really [bleep] performance. Anyone?
Thanks,
matt
Old 10-10-2004, 07:33 PM
Default Re: 15\" Powerbook test results
I have a 15" 1.5Ghz. It's fine for tracking, and simple sessions, but it's easily overwhelmed with lots of tracks and, for instance, Reason.
Quad 2.5 G5, 4.5G RAM
Old 10-10-2004, 08:18 PM
Bhennies Bhennies is offline
I just finished a session on my 1.33 ghz 15" PB that was 38 tracks (6 disabled) and 15 waves plugs- 1 trueverb, 2 6 tap dlys, and the rest EQ"s and comps. No problem- 3/5's CPU usage.
Digi 002R, RME 8 i/o, DP 4.5, PT LE 6.4
Old 10-11-2004, 07:26 AM
16yearsjeff 16yearsjeff is offline
i have the alu 15" 1gh. i recently recorded 18 simultanious tracks at a live show for 3.5 hrs and it didnt even flinch. granted, i only use it for tracking so i wasnt using any plugs. after i track i go home and mix on a powermac g4. the most important thing that i have leanred about my pwrbook is that the power settings have to be set to highest performance. good luck. -jeff
www.sonicdisorder.com
Old 10-14-2004, 05:21 AM
beholder74 beholder74 is offline
So how do you set the power settings to highest performance???
Old 10-14-2004, 06:13 AM
System Preferences | Energy Saver | Options | Processor Performance
select HIGHEST
This runs the CPU at full speed all the time.
Old 10-14-2004, 09:34 PM
Allen Hallada Allen Hallada is offline
How many here are using the internal drive only for tracking and what buffer settings are you able to record at when using just the internal drive?
Allen
Old 10-15-2004, 08:48 AM
Chris Shaeffer Chris Shaeffer is offline
I use the internal drive at times. Usually I'm on an Mbox when I am and I can record the first 4 or 5 tracks at 125, the I have to up it to 512. Its not as bad with the 002, but I can't really compare because I usually have it on an external drive at that point,
Chris
Old 04-10-2010, 10:36 PM
onetimeonly onetimeonly is offline
Default Re: 15" Powerbook test results
This is quite a bit into the future from the initial post. But I just happen to be using a Powerbook G4 1.5GHz PPC with Leopard 10.5.8 in conjunction with an Mbox 2 with Pro Tools LE 8.0 and just wrote this post about my findings when attempting to update to later versions of 8.0: http://duc.digidesign.com/showthread...99#post1589499
Maybe there are a few people here in the future looking for this information?
Ciao
The Test Results are In!!! dougied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-03-2008 09:05 PM
Results of my MacBook test TimOz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 21 02-08-2007 12:58 PM
My davec test results jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-29-2005 09:00 AM
Why am I getting bad results on davec test? Matt Whritenour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-26-2003 06:31 AM
Powerbook 800/Magma/HD2 test results CraigLearmont Pro Tools TDM Systems (Mac) 0 02-10-2003 08:48 AM
