Old 05-08-2007, 08:49 PM
digijohn digijohn is offline
Default Some Virtual Instruments Can\'t Use Instrument Tracks
Hey guys -
This isn't the end of the world or anything, but could someone explain to me why some virtual instruments can't make use of the instrument tracks in Pro Tools?
I'll give you a fer instance:
I use Trilogy and SampleTank LE. If you create an instrument track and activate these plug-ins, I can't trigger them via MIDI. Now, if you do it the old school way by creating a stereo audio track then create a MIDI track to trigger it, it works fine. What gives?
Other VI's work on an instrument track just peachy, like Strike, Stylus RMX, Kontakt, etc. Is it because the other plug-ins are behind the times?
Thanks for any insight.
John
- System -
12-Core Mac Pro 5,1 3.46 GHz
128 GB RAM
Audient iD44
Pro Tools 2020
Old 05-08-2007, 09:23 PM
spkguitar's Avatar
Default Re: Some Virtual Instruments Can\'t Use Instrument Tracks
Yeah, some of the older versions of plugins don't automatically switch the MIDI output of the instrument track to itself when inserted. You will need to manually assign the MIDI output of those tracks to the instrument you have inserted (and/or make sure you have the latest versions of the plugins installed).
Old 05-08-2007, 09:31 PM
Yeah, which what've had to have of been done with the MIDI track. (what a mouth full)
filo
Aaron Mulqueen - 001 HD Native
Old 05-08-2007, 10:01 PM
Stig Eliassen's Avatar
Trilogy works just fine with instrument tracks here. MIDI output automatically gets routed to the VI.
Old 05-10-2007, 02:37 PM
What's a VI? You wouldn't mind walking me through how you got Atmosphere to work on an instrument track, would ya? I can get it to work fine on an an audio track with a MIDI track triggering it, but not an instrument track. I would really like to know how it's done. Thanks!
- System -
128 GB RAM
Audient iD44
Pro Tools 2020
Old 05-10-2007, 09:11 PM
VI means Virtual Instrument.
Can you see the instrument view on top of the instrument tracks (View > Mix window > Instrument)?
Does the small MIDI meter show any activity when you play?
Some VIs needs to have hardware audio inputs assigned to produce sound on instrument tracks. Maybe Atmosphere falls into this category?
Old 05-11-2007, 05:49 PM
cheekypaul cheekypaul is offline
Hey guys -
John
You are absolutey right, but it's rarely discussed here.
There are facts out there that are not explicitly stated.
One of them is that NOT ALL VI's WORK ON AN AN INSTRUMENT TRACK, sorry for shouting. I shouted because Digi shouted when they announced instrument tracks. (It wasn't an announcement to me).
(for example, pluggo max/msp plugs)
Will it ever change? I don't know.
Also, the Pro Tools compatibility chart is not as straight forward as we or they would like us to believe. (ie. You sometimes have to pay to be on the list) (But that's another topic).
Shoot, I've said too much...
Ignorance is sbsli
PS. Please remember 1. Pro Tools is the best software out there.
2. The bull generated by other software companies is the same if not worse.
Mac Computers/PT12/Lots Of Lacie D2s
2 MIDI Controllers for 2 Virtual Instrument tracks simonzero MIDI 2 06-27-2012 06:50 PM
Virtual Instrument Tracks greenteaki Virtual Instruments 3 03-16-2007 01:51 PM
MIDI Click tracks with virtual instruments? rtm Tips & Tricks 2 03-13-2006 02:36 PM
Instrument Tracks & instances of instruments EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-04-2006 02:34 PM
Virtual Instrument Tracks shadowbox Pro Tools TDM Systems (Mac) 7 06-08-2003 10:10 AM
