Old 05-23-2023, 01:13 PM
Tweakhead Tweakhead is offline
Default Re: Unable to record audio
yes, but where precisely are you trying to actually create the session ?
on your Desktop ? or on the top level of the "Macintosh HD" ?
If it's your Desktop, try launching Disk Utility, run First Aid on the boot SSD, restart.
Re-check Workspace permissions.
Try again.
You are logged in as an Admin-level user, correct ?
Old 05-23-2023, 03:22 PM
perhaps read this thread and see if it gives any more clues:
https://duc.avid.com/showthread.php?t=421798
Old 05-24-2023, 03:54 AM
musicman1985 musicman1985 is offline
The session is inside Macintosh HD. I'm logged in as admin and the permission state that the drive (Macintosh HD) is set for Recording. But still doesn't work.
Old 05-24-2023, 04:50 AM
Sardi Sardi is offline
Originally Posted by musicman1985 View Post
Yes I'm booting from external ssd (apfs). I checked all the permissions for disk allocation . I searched for similar topics and someone stated that it works only with internal hard drive. Thanks anyway.
No.
You can definitely boot from an external drive and run PT from that drive. I’ve done it countless times. You can also record to the boot drive if you choose.
Does this happen on every session? Can you import audio and playback that audio from within PT?
Old 05-24-2023, 10:11 AM
Carl Lie Carl Lie is offline
Hello everyone,
I am using Pro Tools Intro on MacOs Monterey and when I try to record an audio track I get the annoying message "Unable to create record files for one or more tracks. Check your disk allocation and drive permissions." If anybody knows what to do I would be thankful. I already granted full disk permission to pro tools.
Is this by any chance a project that you copied from another system to work on? I had a problem last week with one of those on my new Mac Studio. Disk allocation was correct however I could not add tracks without the error you describe. I got around it by creating a new session and importing the tracks.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
  #16
Old 05-24-2023, 12:53 PM
In Catalina onwards the primary volume is read-only, which is why I asked about the exact location. If you just open your Macintosh HD and try to create a simple folder on that top level, you cannot. It appears to the user as one single volume - but it's not. There is actually a hidden volume for the all user data. The actual system Macintosh HD Applications folder for example is read only, and there is also a user-level Applications folder where all your installed apps get installed - and it's on a separate partition with the title addition "- Data". It appears as if all your apps are in one place, but they're not. That's why I asked about the exact location that you're trying to create the session. Apple changed this for security reasons. If you ever boot a multi-OS mac into a macOS older than Catalina (eg High Sierra), you'll see this extra partition appear on that desktop.
Your most simple solution is either to create your new session on the desktop of your user-account, or preferably on an external, correctly-formatted drive (with the correct Workspace permissions).
You can also make sure of desktop folder permissions of say a "Pro Tools Sessions" folder, by select it then Command+i, Sharing & Permissions, add Administrators, change all to Read & Write, click cogwheel (Apply to enclosed items), confirm+password, restart. Make sure the permissions are kept. Save all your sessions in there.
If you really want to get into the depths and complexity of the hidden partition read this.
  #17
Old 05-25-2023, 09:19 AM
K Roche's Avatar
K Roche K Roche is offline
I am confused why are you booting the Mac OS from an external drive ?
Why not boot the Mac OS from the internal HD, and then if you need more storage for PT, have the external as your PT session storage drive.
Also depending on which PT version you have, in later versions the default session location is in the Mac Documents folder , so you will have to change that in the PT export or bounce widow.
Me I do as Tweakhead noted, my current PT sessions I am working on I store in Folder on my desktop labeled "PT Sessions " and then when I know they are finished I move to and external drive to make more room on my internal HD
System :
Avid Carbon interface , PT Ultimate 2023.6 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Ventura 13.2 .1
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
  #18
Old 05-26-2023, 12:37 PM
I'm booting from external ssd because the internal hdd is slow.
  #19
Old 05-27-2023, 07:25 AM
K Roche's Avatar
Maybe you should list you actual system specs
But since speed for boot up and PT launch is not really a factor
Seems to me the issue is you trying to run the OS and PT on the SSD but trying to store the sessions on the HD
So IMO 2 options
#1 boot OS and run PT on the internal HDD drive, and have PT store the sessions on the external SSD My guess is you will not see much if any speed issue with this since you will still be retrieving the audio files via SSD This is the method that was used for many years.
#2 leave the OS and PT on the SSD and store the sessions on the SSD also
Booting and running PT from an External SSD and then trying to store your sessions on the internal HHD is counter intuitive (speed wise)--- because you will be writing and retrieving the audio via the HDD and defeat the purpose of the external SSD ..
System :
Enjoy the Journey
.... Kev...
  #20
Old 05-28-2023, 09:06 AM
My mac runs too slow on the hdd. i tried to save the session on another external ssd but get the same error. I appreciate your effort but I think we have come to the end of this topic.
Unable to record Kurzweil audio engine in PT11 insightsono macOS 1 04-27-2018 10:16 PM
Unable to Record (digitize) a Regular Midi Track to an Audio Track JuicyMusic macOS 9 02-27-2013 08:52 AM
Unable to record live audio Phresh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 05-29-2011 02:27 PM
Unable to Record BFD Audio paxfax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-19-2009 02:49 AM
unable to make my FW drive "audio record volume" andycopeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-18-2008 08:11 AM
