Old 07-07-2021, 12:52 PM
ToneFreq ToneFreq is offline
Default Plug-In Automation Enable Menu gone! 2021.6.0
Hi all,
just upgraded to Ultimate 2021.6.0 from 2021.4 and i see that the Plug-In automation menu within the plugins do not show the parameters. this is a MAJOR issue as i'm mixing clients projects daily. Has anyone found this problem and know of a fix?
File Type: jpg Screen Shot 2021-07-07 at 12.48.33 PM.jpg (50.3 KB, 0 views)
Old 07-07-2021, 01:13 PM
daeron80 daeron80 is offline
Default Re: Plug-In Automation Enable Menu gone! 2021.6.0
Working normally here. You might get a helpful reply if you let us know the relevant computer and OS details. Note that on Mac, Catalina users seem to be flying, while Bug Sur users are in hell.
David J. Finnamore
Old 07-07-2021, 01:18 PM
Of course,
2018 Mac Mini 3.2 Ghz 6-core Intel i7
Catalina OS 10.15.7
Old 07-07-2021, 01:49 PM
Is it all the plugins? Check if EQ3 1-Band has eight parameters available to automate.
Edit - or maybe McDSP's "ultimate" doohickies don't support AAX automation quite right in 2021.6. If you have the individual plugin, try that and see.
David J. Finnamore
Old 07-07-2021, 04:02 PM
Unfortunately, it's every plug-in
Old 07-07-2021, 04:38 PM
Reml@P Reml@P is offline
Working fine here as well.
It must be an issue with your system config somehow.
FYI, I'm running PT "vanilla" on macOS 10.15.7 (2020 iMac 5K 10 core i9)
Old 07-08-2021, 04:53 PM
What happens if you turn on Plugin Controls Default to Auto-Enabled in Mixing preferences then instantiate a new plugin? Do the automation parameter lanes show up in the drop down menu in the edit window? Also, what about it you ctrl-opt-cmd click a control on the plugin? Does the context menu for enable parameter for automation show up?
Scott Gatteño
Old 07-08-2021, 10:15 PM
Originally Posted by ToneFreq View Post
Hi all,
This is off topic but, I wasn't aware that there was a Protools 2021.4 version. From what I've seen, the last version before 2021.6 was 2021.3.1. I just use Protools vanilla and not Ultimate so I may have missed that version, but I was checking in the "Technical Alerts" section where new releases are announced and also did not see a Protools 2021.4.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 07-08-2021, 11:12 PM
Top Jimmy's Avatar
I would expect that trashing prefs and databases so all the plugins get scanned on the next start would likely resolve the problem.
James Cadwallader
Old 07-09-2021, 02:00 AM
I'm guessing a typo - although 2021.3.1 was released in April, so technically you might think of it as 2021.4.........I believe we all argued about it at the time.
Enable Automation In Record Peter Baird Pro Tools 11 0 02-16-2014 11:56 PM
Global enable plug-in automation? reichman Post - Surround - Video 2 02-17-2011 07:13 AM
enable automation on several tracks vudoo Tips & Tricks 2 10-20-2010 10:59 AM
Can't Enable Automation (all greyed out)? rdolmat Pro Tools TDM Systems (Mac) 5 06-30-2009 12:10 PM
Plug-in "enable all" automation parameters reichman Post - Surround - Video 14 07-23-2007 07:37 AM
