Advanced Komplete Kontrol Integration Not Working
FIXED. Had to remove the FB360 from the plugin folder.
Hello, I have followed the steps outlined on N.I.'s website and made the appropriate changes in PT 2021.10 but my S49 mkII keyboard still has no control over any Pro Tools functions (transport, faders, etc.) All N.I. software is up to date. Can anyone offer any suggestions. Thank you MBP 2019 OS 10.15.7 Pro Tools (Regular) 2021.10 Last edited by underground123; 11-03-2021 at 03:24 PM. Reason: Fixed |
Re: Advanced Komplete Kontrol Integration Not Working
In komplete kontrol preferences under "midi" check all the input output buttons. Try that.
Sent from my SM-G986U using Tapatalk |
[QUOTE=arche3;2618199]In komplete kontrol preferences under "midi" check all the input output buttons. Try that.
Thanks, unfortunately it did not make a difference. Other notes: -When I use the transport via my laptop keyboard it shows on the S49. -If I mute or solo a track it shows on the S49. -The instrument in protools shows on the S49 screen but the knobs will not change any of the parameters. Basically, once Pro Tools "connects" to the S49 the keys, pitch and mod wheel work and the display will show any changes you make to the NI instrument within Pro Tools but the S49 transport controls and other buttons and knobs will not change or control any software parameters. I have tried changing settings and restarting many times. |
Komplete Kontrol Host Integration | ReynaldoPena | Pro Tools | 31 | 03-24-2022 09:05 PM |
Komplete Kontrol S88 not connecting | Kiwiflip | Pro Tools 2018 | 2 | 01-30-2019 08:44 AM |
Komplete Kontrol S61 | KaneStarkey | Pro Tools 12 | 0 | 11-09-2015 04:14 AM |
Pro Tools 12 with NI Komplete Kontrol | randb1 | AAX Plug-ins | 7 | 05-27-2015 02:20 PM |
PT and Komplete Kontrol | LAMEREALM | Virtual Instruments | 25 | 05-26-2015 04:58 AM |
