Old 05-29-2017, 07:39 AM
lederhosen lederhosen is offline
Default Mono/Stereo plug-in
Hey all,
What is the best way to keep a mono track mono, when inserting a reverb mono/stereo plug-in? I'm noticing the track is converted to stereo when I place the plug-in on the track.
I was told that panning the left and right channels of a stereo track to center is not the best way to go mono, as this could cause phasing issues in which you are essentially placing the left and right channels on top of each other. Instead take either the right or left channel. If this can remedy the mono/stereo plug-in problem, how can this be done?
Appreciate any help.
Old 05-29-2017, 07:53 AM
Default Re: Mono/Stereo plug-in
Reverb plugins are best used in a send-to-aux track configuration. Especially if you need to keep the original source mono. Also, depending on the situation, panning a mono track to one side and sending to a mono reverb panned to the other side can be very effective.
Old 05-29-2017, 08:30 AM
Drew Mazurek's Avatar
Originally Posted by lederhosen View Post
Hey all,
You can't. By definition you've made it a stereo audio path.
As Albee noted, you shouldn't be using Inserts for time based effects anyway. Why?
1. it's inefficient, you end up using more instances since no other track can access it.
2. also because any plugs that come after are now stereo as well, unnecessarily.
3. control for the amount of effect is buried inside the plug, not on a send where it belongs.
4. more importantly, when you adjust the amount using a mix control inside the plug, you are turning down direct signal while turning up wet signal, not simply adding the wet to the dry as it is when you do it properly.
Having said all that... there are occasions where I will Insert a mono slap delay that is exclusive to the track and that I know I won't be touching.
www.drewmazurek.com
Old 05-29-2017, 01:26 PM
amagras amagras is offline
If the plugin has that option, insert it in (mono). I know the spring reverb stompbox has that.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 07-27-2017, 08:46 AM
Appreciate all the responses guys.
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
mono to stereo plug-in Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-23-2004 01:01 PM
Mono to stereo plug-ins not showing L/R pan trostals 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-20-2004 09:28 AM
Mono to stereo plug-in, does it exist? Boom Chic Pro Tools TDM Systems (Mac) 19 11-24-2002 12:17 AM
How do you keep a mono/stereo plug-in mono? Baixo Tips & Tricks 8 01-05-2001 11:03 AM
