how do i set up my external HD?
Hi, Newbie here
I have protools 10.3.1 just added a external hard drive. How do I set up pro tools to utilize this drive to reduce strain on my computer? I have 10.8 Mountain Lion Thanks, jd |
Re: how do i set up my external HD?
there is no real reducing strain on the computer afaik
its just pro tools likes to work with it installed on system drive and using another drive for tracking/mixing off.. in a pc you simply dump your project folders into it.. run as normal.. same for recording... save project in said ext hdd... you're done pro tools handles the rest.. as long as the audio files folder for the project is within the folder which resides in the hdd you're good to go... i dont know if there is anything else to be done on a mac but its pretty straight forward... afaik there are no additional settings to be selected in pro tools... i run an ssd for tracking/mixing projects... saved projects reside in this hdd... done..
kickin' at the darkness 'till it bleeds daYlighT
for Mac,
format HFS+ Journal non-case sensitive then Get Info on the drive as check the Ignore Permissions box and away you go
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Why does Avid recommend external USB over external Firewire for audio drive? | DJ Hellfire | Pro Tools 10 | 10 | 03-29-2012 09:39 PM |
External dedicated external hard drive | JuanCarlos | General Discussion | 1 | 02-15-2010 03:11 PM |
Backing up Audio Drive (External) and External HD Question | JCWarrior | Pro Tools TDM Systems (Mac) | 2 | 04-13-2008 04:42 AM |
using an external pre with the 002 | Snyderman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-28-2004 07:27 PM |
Using External A/D for 16 Bit Mix? | JB3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 09-08-2002 12:33 AM |
