Adding bulk Unique ID's
Hey all, quick question i hope you can help with-
I have a large FX library i'd like to make sure that all sounds have their Unique ID's stamped on them. Other than importing tens of thousands of sounds into pro tools, does anyone know of a way to add Unique ID's to files in bulk? Thanks for any ideas.
We, in post sound, are illusionists, not magicians. |
Re: Adding bulk Unique ID's
In Workspaces, build database, right click drive/folder where sounds are
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Ya know, for the life of me, i can't find anything in a workspace window that mentions 'build database'. I right clicked on everything i could. I found a 'update index", but that doesn't seem to do the thing? Am i having a slow moment and missing something?
Sorry... seems that doesn't change the Unique ID. In the waveform metadata it's the OriginatorReference field.
Soundminer Mirror function
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
That will transfer the unique ID if it already exists but I don't see anywhere it'll generate a unique ID for a batch of files. Am I missing something?
Can you go to the finder in list view, open all sub folders (Cmd->?), select all (Cmd a), then drag into the clip list on a blank session?
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12 |
My mistake. I thought you could create a new ID.
Have you tried "save copy" on a session full of files, including audio? You can preserve folder structure and make a new FX library that way. But I can't say whether PT actually adds IDs in this situation.
If all else fails and you really need this, I know I have some code somewhere which adds a unique ID chunk or replaces it where already present. I'd have to go digging for it and you'd probably have to fix and compile it yourself... and it might not work any more. |
Bulk process for Unique ID | SouthFresh | Pro Tools 12 | 0 | 01-29-2016 04:48 PM |
Bulk spotting in PT LE | Jonothon77 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-03-2011 04:22 PM |
Bulk Spot | Drew Mazurek | Pro Tools TDM Systems (Mac) | 1 | 04-14-2003 12:53 AM |
where to get bulk connectors ( trs, xlr ) | JGriffith | Tips & Tricks | 11 | 06-26-2001 11:43 AM |
Bulk Bouncing | JLEpperson | Tips & Tricks | 4 | 03-21-2001 06:18 PM |
