Old 01-31-2012, 11:41 AM
barakka barakka is offline
Default Setting up MBOX 3 PRO for Surround
Trying to set up my MBOX 3 PRO for surround but having no luck, how the heck does the MBOX PRO software mixer work ? There is basically nothing in the manual about it and I can't for the life of me get it to route the outputs to the correct speakers !!!
Has anyone got this setup and can tell me how to configure the software mixer in the setup.... ?
It's fine if I want stereo, but as soon as you try to route outputs to the 3/4/5/6 outputs it starts mapping them as stereo pairs... ARRRGGHHH
Originally Posted by The Mock Turtle
“Reeling and Writhing, of course, to begin with, and then the different branches of arithmetic -- Ambition, Distraction, Uglification, and Derision."
Old 01-31-2012, 12:45 PM
Default Re: Setting up MBOX 3 PRO for Surround
Ok... got it... typical hours spent banging my head and after I post a question I figure it out :)
Anyway will be good for if anyone else gets stuck like I did if I post up what I did..
In MBOX PRO Setup->Output Setup:
Renamed the Output pairs to my connected speakers;
L/R
Ls/Rs
C/LFE
and ticked Master Vol for all 3
In the main mixer;
1st tab (L/R)
Set to Stereo Mix 1
Set Software Returns 1/2 to 0dB panned hard left and hard right
2nd tab (Ls/Rs)
Set to Stereo Mix 2
Set Software Returns 3/4 to 0dB panned hard left and hard right
3rd tab (C/LFE)
Set to Stereo Mix 3
Set Software Returns 5/6 to odB panned hard left and hard right
Master Fader
Pan Centre
Width dial 100% - hard right
Obviously if you connect the speakers in a different order you need to name them appropriately. In Pro Tools the I/O output config for this order is a 5.1 path with;
L R Ls Rs C LFE
Old 04-06-2012, 12:48 PM
rogerhavoc rogerhavoc is offline
Great info!! Also, if you want to be able to hear all the speakers simultaneously, the "Control Room Assignment" option should be set to "None"
@barakka, I would be interested to see you are managing your IO settings!
Cheers,
Roger
www.whitenoiselab.com
MacPro 3.5 GHz 6-Core Intel Xeon E5 - Pro Tools Ultimate + HD Native + HD OMNI
MacBook Pro 2.9 GHz i7 16GB Ram (Retina, 15-inch, 2016) - Pro Tools Ultimate + Apollo Twin
iMac 27" 3.4 GHz i7 32GB Ram (Late 2012) - Pro Tools Ultimate + Mbox Pro (3rd gen)
Old 07-16-2013, 07:58 PM
Austin4 Austin4 is offline
Thank you so much for this. I was afraid I'd have to get another output device, but I'm glad to see I can still use my Mbox Pro 3.
Old 05-12-2014, 11:19 AM
agustinlj agustinlj is offline
HERE: setting mbox pro 5.1 surround outputs
http://www.mediafire.com/download/se...RO+5.1.MboxPro
1=L
2=R
3=C
4=LF
5=LS
6=RS
Old 06-24-2015, 03:29 PM
benjaminmusic benjaminmusic is offline
Thanks for the post! I am getting the channels to work but my L/R is playing regardless of the channels I assign to.
For example I did a test. A mono track, assigned to center. My center is playing but my L/R is also playing. Maybe my i/o bus is whacked, I just can't seem to figure it out. Any idea?
Thanks.
Ben
Old 06-25-2015, 07:33 AM
postprosound postprosound is offline
Barakka,
Chanel assignments for the Mbox 3 pro are assigned in the I/O page. There you can choose L to go out 1, C to go out 2, R to go out 3..... or however you choose to set up your room.
the mbox pro setup is used for headphone assignment, with the exception of the control room knob set up.
Hope this helps.
We, in post sound, are illusionists, not magicians.
HTML code is On
setting up a 7.1 surround session? Brooksalexander Post - Surround - Video 14 06-10-2011 08:54 AM
setting up surround in a small room neilbenezra Post - Surround - Video 0 04-29-2008 07:43 AM
setting up PT surround seibu1 Post - Surround - Video 5 04-29-2002 03:20 PM
Surround divergence setting for Dolby SR Bokir Tips & Tricks 0 11-16-2001 08:13 PM
Setting up for Surround agus ProControl, Control|24, Command|8 5 07-26-2000 08:36 PM
