How to fix a MBOX Defective Channel
Hello everyone!
I recently move my studio to a new location and set up my Pro Tools LE on a new Computer. When I attempted to record a Stereo Channel, only Channel 2/Right was working. I looked at the gain knob and its physically PUSHED into the MBOX by about a 1/3 inch or so. I am still getting a signal from CH1/LEF, however its stuck at -40db than what my right channel should be (Both knobs are at the 12 - 3OCLOCK positions, like normal) Does anyone know of any solutions to correct this, or should I request a replacement unit from DigiDesign? Thanks! -- Edit -- I Test both the input L and R signals, they both work. Channel 1/L INPUT set to LINE INPUT (XLR OFF, PAD OFF, PHANTOM POWER OFF) (Even test Mic Input, same issue) Channel 1/L OUTPUT/RECORD INPUT LEVEL Rotary Gain Knob looks like it was forced INTO the unit, by about 1/4 to 1/3 an inch / this likely occurred due to force applied to the front of the unit during packaging, handling, transit, or installation. Channel 1/L INPUT/OUTPUT/RECORD INPUT LEVEL works (sorta) when I Hold My Fingers in a certain position while recording, but it stops working after I let go of the Knob (goes to near silence or -40dbu compared to Channel 2/R). It takes me about a minute each time for me to find and hold that 'Position' again. Channel 2/R works as intended While I have had similar instances where knobs were 'forced' into different units (like mixers or midi devices), however they was still operational, however in this case, the MBOX Channel 1 its not operational. |
Mbox 3 possible defective device?? | andrewbrg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-07-2013 03:36 AM |
Mbox 3 Pro concern- defective? | david cos | macOS | 0 | 09-04-2011 04:09 PM |
Defective Avid MBOX 3 Unit? | sp0t619 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-19-2011 09:33 PM |
defective mbox 2's???? | wade12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-29-2006 05:39 AM |
Is my MBox Defective? | js54 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-13-2006 09:00 PM |
