Old 10-18-2013, 10:08 PM
Rectifried Rectifried is offline
Default If you could only have one.. Control or Mix surface?
have both on loan... I know: keep both!
but just a random survey, of long time users.
Hal Cragin On the DUC Since The Year 2000 AD
Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2]
Old 10-19-2013, 02:50 AM
Default Re: If you coiuld only have one.. Control or Mix surface?
The product line is cleverly designed so every unit is lacking something that you will miss without buying the other in the long run.
The essentials:
Control: No flip function
Mix: no customizable soft-keys
Personally, I'd get the control first and at some point a mix. Without the soft-keys your life won't be much easier than having no controller at all. Apart from the faders of course.
But it depends on what you do mainly. Since you have both units on loan you simply have to work with them a bit to find out yourself.
Old 10-19-2013, 06:24 AM
Emcha_audio's Avatar
The mix, I prefer to have 8 faders than 4, and most none editing function are available from it. For editing though, I keep the keyboard close.
Manny.
Wave-T.com
Old 10-19-2013, 10:01 AM
good point about the functionaltiy.. cant figure out how often Id use each thing.... since im used to nothing for so many years
8 faders is great for the master vcas rides or multi gtrs..
with all the new summing things at aes ... daw control is still missing from most, and eucon while buggy... is supported
Old 10-21-2013, 05:41 PM
noiseboyuk noiseboyuk is offline
The Mix, by a mile. No display on the Control for the faders massively limits its usability (the old "can't see what you're doing" conundrum). I've never found the soft keys or shuttle controllers all that useful, I tend to just get around quickly on the DAW. With control surfaces, it's all about the faders, clear displays and quick switching between modes for me.
Old 10-22-2013, 01:54 PM
Brent_Sydney Brent_Sydney is offline
Depends on how you use faders.
If you just want to use trim and touch automation and bank around grab a mix.
If you like preview, autojoin, use latch and other more advanced automation features you will probably appreciate the touch screen and its macros and ability to put anything on it.
I regularly unplug a mix and plug in my control that I bring with me when I freelance.
I normally only ride 3-4 faders at the same time and layouts and the ability to "follow selected track" makes 4 enough to not feel cramped imho.
Thats coloured by my experience on an icon, used to working in a way that the faders in front of me are often not laid out the same as they are in my sessiona and using a focus fader to access plugins for regularly scene based automation.
Gross generalisation: for music Id get a mix, for post Id get a control
Old 10-22-2013, 01:56 PM
Fyi
http://www.protoolsprofessional.com/...rtist-control/
Old 10-23-2013, 09:40 PM
Hey thanks great reply..
I like your focus fader +3 ..good idea
Im not coming from any surface so trying to get a flow going... theres no in depth video out there it looks like... just have to read the manual and see what I need as I go. all workfow ideas are welcome [needed]
Old 10-24-2013, 12:23 AM
Xill Xill is offline
Location: Planet Earth, Milky Way Galaxy, Observable Universe
Mix+Transport, if you can test it before buying to make sure you have no compatibility problems.
Old 10-25-2013, 05:00 AM
OTARI's Avatar
OTARI OTARI is offline
None.
If you don't want to become a beta tester for soft- and hardware that should be working in the first place (since it's been out for how many years now?), stay away. Run.
“An intellectual says a simple thing in a hard way. An artist says a hard thing in a simple way.” - Charles Bukowski
003 control surface (As audio) & control 24 as surface crizdee ProControl, Control|24, Command|8 7 01-04-2016 12:30 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 07:03 PM
Digi 003 Control Surface Mackie Control Mode ctmusicman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-23-2008 07:23 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
