Re: "Sticky" for Correct Uninstall-Reinstall Process for Pro Tools!
Thank you for your response! Do you recommend the "Safe" or the "Clean" uninstall option? Thanks! |
That's really your call. A Clean Uninstall is more thorough but will take longer since you'll have to run the Avid Virtual Instruments installer after installing Pro Tools. If your system has been pretty solid, then a Safe Uninstall (and then a PT install) should be sufficient.
Excellent!
Do I need to run the Avid Virtual Instruments 10.3 Installer if I move up to Mountain Line (10.8)? You wrote in another Thread "The Avid Virtual Instruments installer was updated to 10.3 on the Mac side simply for Mountain Lion.", but I'm not sure exactly what that means (Compatibility, Gatekeeper, etc...). Thanks greatly for the help! |
As neither 'safe' or 'clean' uninstalls affect IEP or e.g. TL Space, I guess we can take it that we do not need to run these installers again. The only doubt/issue still 'up in the air' (I believe) relates to the VI installation over IEP (risk of Structure Free impacting the Structure 'full' setup). So, if we deduce that the only change to the 10.3 VI installer is Mountain Lion compatibility (possibly 'signed' for Gatekeeper?), then a 'safe' uninstall would appear to be the safest bet at this stage? DigiTechSupt - it would be really useful if you would close off this topic with confirmation of what exactly changed with the 10.3 VI installer + if it is run following a 'clean' uninstall over IEP, will Digidesign/Avid folder structure and Structure itself be 'in order' ... then make this a 'sticky'. Thanks again! |
Just noticed that DigiTechSupt was kind enough to also post in one of the other threads on this topic - see below / http://duc.avid.com/showthread.php?t=328401
******** Quote: Originally Posted by Righty27 I see that Avid have a new 10.3 VI installer as well as the main PT installer. Instructions suggest I first uninstall 10.2 - what would this do to my PTIEP installation? Will I need to re-install this - I guess I may have the downloads on time machine? Any IEP users out there moved up to 10.3? It shouldn't do anything to your PTIEP installation. Pro Tools Instrument Expansion Pack (PTIEP) is different than the Avid Virtual Instrument (AVI) installer. The AVI installer was updated to 10.3 on the Mac side for Mountain Lion. If you do a clean uninstall before reinstalling PT, then you'll need to run the AVI installer. If you do a Safe uninstall before reinstalling PT, you won't need to run the AVI installer. __________________ Avid Audio Tech Support ******** Looks like the IEP (and I assume TL Space) installations will 'survive' whether one goes for a 'clean' (followed by 10.3 VI installer) or 'safe' uninstall (in which case, the new VI installer does not need to be run). Please post your results here. FYI, in another similar thread ( http://duc.avid.com/showthread.php?p...52#post1966452 ), jrsyer posted: I installed the instruments right over the old. Expansion pack works perfectly. I had updated them all prior to 10.3. |
#16
Step-by-step PT removal guide in a readme.pdf is a great idea...but
an installation applet (for a reasonably stable program) should do that automatically. The install applet should post a log of what it will be doing and then what it has done...
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon |
#17
Agreed ... thing is that e.g. the PTIEP installer already had (known) issues before the 10.3 upgrade. It hasn't been updated for some time and I'm not sure if we're waiting/hoping for Avid to address this or AIR (since Avid recently divested themselves of AIR).
#18
Done. For the record:
(i) Clean uninstall - subsequently checked and the "AIR Content" + "Trillium Lane" folders remained (ii) Mountain Lion 10.8.2 upgrade (iii) PT 10.3 installer (iv) 10.3 VI installer Everything, including third-party plugins, appears to be in order ... once installed and 'fixed', IEP evidently survives PT upgrades (essentially because it remains untouched) ... not surprising that users are cautious however! AIR/Avid - please fix the IEP installer + thanks again DigiTechSupt! |
#19
I'm glad Avid has a blanket recommendation for uninstall, since it only takes about a minute and a half, and people are less likely to have issues. Not sure why there's any hostility about this.
#20
Not really any hostility to the recommended uninstalls ... I suspect that users who have recently installed IEP in accordance with Avid's (Digidesign's) guidelines (a long process in itself exacerbated by the size of the downloads if one doesn't have the DVDs) are just being extra cautious to reduce the risk of ruining their setups ... the initial installation experience has probably made us extra-wary! :)
"Clean Uninstall" Pro Tools 10 after moving over to Pro Tools 11? | NBarnes21 | macOS | 13 | 02-28-2014 10:26 PM |
Pro Tools LE 8 "quits unexpectedly" at launch, after reinstall, and database delete | MWPOP | macOS | 10 | 08-19-2013 05:19 PM |
sticky "Firmware related errors and resolutions for HD|Native Hardware" doesn't wo | basicbass | Pro Tools HDX & HD Native Systems (Win) | 1 | 04-03-2013 05:55 AM |
Make Audiosuite plugin "sticky" | Meads | Pro Tools 9 | 0 | 11-24-2010 07:40 PM |
"sticky" Markers? Any ideas? | cksbcville | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-25-2008 02:53 PM |
