Old 10-31-2016, 08:25 AM
Hitsoundtech Hitsoundtech is offline
Default Strange Sends on Fader behavior
Is it just a bug, or a deisred behavior, that when I am on an OUTPUT layer, and solo it (for example a St Aux Master) then nothing happens. No sends on Fader.
Even if I hit the attention twice, it just makes a spill and not a Solo+Spill what would be desired for monitor mixing...
ALthrough if I am on the Venue mode, then in the maseter section when I do the same to a stereo Aux MAster, it works like I want....
Thanks,
Tamas
Old 10-31-2016, 10:02 AM
RyanJ's Avatar
RyanJ RyanJ is offline
Default Re: Strange Sends on Fader behavior
In Options > Busses, do you have "Sends on Faders follows AFL", checked for the monitor bus that you're cueing?
Ryan John
Principal Product Manager | Avid Live Sound
ryan.john@avid.com
Old 10-31-2016, 10:03 AM
RyanJ's Avatar
Oh, sorry, yes, you're on an outputs page. None of those could be sending into any mix.
So if you were to flip to sends on faders while in that mode, you would have no faders active at all.
This is intentionally disabled.
Ryan John
ryan.john@avid.com
Old 10-31-2016, 10:08 AM
Thanks,
I did expect that while being on the OUTPUT layer, when I spill+solo an AUX master, then the same happens, as when I do it in VENUE mode on the master section's 8 Faders with an SUX master....
Obviously this is not the case....
Also I can not combine Spill + sends on fader from the universe view, so that is just an option in the VENUE mode???
Thanks,
Tamas
Old 10-31-2016, 10:24 AM
RyanJ's Avatar
There's a bit of confusing logic on the spill + sends on faders workflow. Everything within the universe view is a single mode, meaning you can be in attention mode, solo, mute, spill mode etc. I've found that it's not the most effective, so I'm hoping to change a bit of the logic there so a user can be in more than one at once, hence a user should be able to solo AND spill with one press... Working on it.
Ryan John
ryan.john@avid.com
Old 10-31-2016, 10:47 AM
That would be very useful indeed ;-)
Thanks,
Tamas
Fader Flip (Sends to Fader) Mode ibanman555 Third Party Interfaces 10 08-24-2020 07:54 PM
*BUG* Pre-fader sends revert to post-fader upon session restart Nico Breeze Pro Tools 11 7 07-11-2014 10:47 PM
Fader Meter Behavior in PT8 and Fader Weights DrFord Pro Tools TDM Systems (Mac) 4 01-08-2009 02:23 PM
Strange 5.1 Master Fader Behavior When Bnc to Disk kcupper Post - Surround - Video 3 03-02-2006 07:10 PM
what about this strange behavior? AuraMaris Studio Pro Tools TDM Systems (Mac) 4 10-25-2004 02:11 PM
