Re: Intel Turbo Boost 2021.6
Like Kyle said, TB is active by default, if the mac intel processor supports it. You can't enable/disable it, or even see its enabled status without software like Turbo Switcher mentioned earlier. And it has only two states; on or off, for all processes including PT.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
If you select the Turbo Boost switch in PT, the processor ramps to its maximum speed and stays there. That's not the same as leaving it to switch speeds as it sees fit. In addition, when you quit PT, the processor stays ramped up at maximum speed. Dominic |
Anyway, the free version of Turbo Boost Switcher is easy, stable and very useful. In combination with Macs Fan Control to manually set fan speed, I have all I need for full control of my macs temperature and performance.
Worse than that, the OFF setting appears to persist through a reboot, at least on my machine, on the two tests I've done so far. So, switch TB off in PT, quit PT, reboot machine - now the CPU won't boost even though you haven't launched PT at all since the reboot. This needs a bit of a fix I think. Dominic |
#16
How are you seeing that the CPU is running at its max speed and stuck there? And what do you mean by “max”? Non-turbo boosted speed? Or turbo boosted speed?
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
#17
PT is doing something it shouldn't (persisting settings) but your explanation is right. Please see my post in reply to Kyle........ Dominic |
#18
What I think has happened here is because I had a pre-release version of 2021.6 (to update the firmware on my Carbon), the Turbo Boost had been switched off on my machine for a few days. I didn't realise, except that I had noticed my web browsing was a bit sluggish. When I lauched PT and turned Turbo Boost on, it restored my machine to its former normal setting, which in the case of the Mac Pro 7.1, is to boost most of the time. So it looked like my clock speed was being pinned at a high level, but in fact, that's where it normally is. (I'm using the Intel Power Gadget to monitor the clock speed). So, for people with laptops, turning Turbo Boost OFF is going to stop/reduce laptop fan noise during use of PT. But it's also going to leave them with a slower machine when PT isn't running. I really don't think you should persist this setting after PT is quit. For users like me, who have a new Mac Pro, turning Turbo Boost off just cripples the machine, again both when PT is and isn't running. There's no need for it so I will just turn it back on and forget about it. I think it's really good to have the setting available inside PT, I just think you should return the machine to how you found it when PT is quit. Dominic |
#19
Im on Intel Mac Pro 6.1 12 core E5-2697 CPU Mojave latest upgrade.
Can this missing feature be the Catalina or Big Sur related ? |
#20
Perhaps you should install the free version of Turbo Boost Switcher .. http://tbswitcher.rugarciap.com/ This is the program Ben mentioned above, and I've got the paid version for my laptop, so it's a legitimate application. Install it - see if it will let you disable Turbo Boost. The free version forces you to do it manually each time - the paid-for version will allow you to persist the setting or set conditions for when Turbo Boost is allowed. But the free version is all you need to see if that control is possible on your machine. Dominic |
Intel Turbo Boost Max 3.0 | Spyderrp7 | Windows | 8 | 07-14-2017 10:29 AM |
I disabled Turbo Boost and Pro Tools seems more stable | jacko | Pro Tools 12 | 4 | 09-19-2016 03:52 PM |
Windows 8.1 Config: Turbo Boost question | 23audio | Windows | 8 | 08-27-2015 01:26 PM |
Intel Turbo Boost causing problems with PT 9? Anyone know how it be turned off? | Georgerob | Windows | 0 | 11-22-2012 03:13 AM |
New Mac Pro Feature - "Turbo Boost" | JSR | Pro Tools TDM Systems (Mac) | 10 | 03-06-2009 02:19 PM |
