"Lacie" not an audio playback volume
I just spent 2 hours searching so I wouldn't repeat a question as most newbs do and still couldn't find an answer so I throw myself to the experts here to possibly guide me through this endeavor.
Running Mbox 2 through my Mac Pro with a Lacie 320G external hard drive. I am running PT 8.0 as well and am kind of new to Mac so I am really a novice. I am trying to setup my disk allocation to send everything to the Lacie rather than Mac HD but every time I try to send a session file to the Lacie this way I get the error message of "Lacie" is not an audio playback volume. I have no clue what this means or how to save my sesions there. I also cannot click on any session files in the Lacie and open up the session. Any ideas, tips or advice is well appreciated. Thank you. |
Re: "Lacie" not an audio playback volume
This may help.... It's from Digi's site.
http://www.digidesign.com/index.cfm?...5&itemid=23114 I didn't see anything on there that said USB 2.0 Drivers were compatible for recording. Is your Lacie drive a usb or firewire? Anyways, if it is firewire, check the specs of what Digi requires and if they match up to what your external drive is.... Then go from there.
____________ KJM Studios Composer for Film, TV & Video Games |
Actually it is a USB 2.0, if I need to I'm sure I can switch the connection to a firewire. Thanks for the link and reply, I will try to reformat the drive to a MAC OS Extended drive. Maybe that'll work.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
I didn't look @ the link, but did u go to the Workspace & try & jus change it to Record(R) Lacie drives come Mac formatted...
I see the USB drive does not play nice. I'm going to look for a USB to Firewire connector.
Workspace? No, I only went into the the setup, disk alllocation and tried to set it there. I get that message above and then I get booted out of PT. Thanks for your help, I appreciate the patience. |
U can't change it in Disk Allocation...
I think you're missing the point. A USB to FW connection won't change anything, you need a drive that IS FW, and not just switched via cable. USB is too slow and problematic to use as an audio drive, and just switching the cable won't improve the speed at which information is being written to the drive.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Jeez, how in the world did I miss that!?!?! I did a 2 hour search and didn't find that.
So, besides setting my disk utility to reformat the drive, my Lacie drive, which is plugged into a USB port to the tower is still going to need a Firewire connection. Correct? Sorry for being such a newb. |
8.0.3 giving "not an audio playback volume" error on hot swappable drives only | coolseethie | Pro Tools TDM Systems (Mac) | 24 | 07-09-2010 09:55 AM |
Lacie Hard Drive "not a valid audio volume" | katiegrey | Storage Subsystems | 0 | 06-14-2010 10:55 AM |
PT 8.0.3 says my ext drives are "not an audio playback volume" | oliarnalds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 02-01-2010 06:49 PM |
After PTLE reinstall my hard drive "is not an audio playback volume" | spudnik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-11-2003 10:36 AM |
Help! "OSX startup is not an audio playback volume" | JLeigh2024 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-30-2003 04:48 PM |
