Old 06-24-2021, 12:05 PM
Default Intel Turbo Boost 2021.6
If you choose Intel Turbo Boost from the Setup -> Playback Engine, when you quit PT, the processor stays 'boosted'. At least it does on my Mac Pro 7.1 under Catalina 10.15.7.
In order to un-boost it, you have to launch PT again and uncheck the box.
Old 06-24-2021, 12:15 PM
Default Re: Intel Turbo Boost 2021.6
I've been using Turbo Boost Switcher for this for a while. It's the only thing that makes my i9 MacBook Pro usable for audio. The paid version is $10 and its totally worth it. http://tbswitcher.rugarciap.com
Scott Gatteño
Old 06-24-2021, 12:40 PM
The switch in PT does the opposite - it turns Turbo Boost on. Which is fine, but it should release it when you quit PT.
Old 06-24-2021, 12:56 PM
koka koka is offline
What is the name of this function on Mac os x Protools 2021.6 ?
Opened Setup/ Playback engine but there is no Intel TB function?
Old 06-24-2021, 01:04 PM
Exactly as described in my first post. It's called Intel Turbo Boost.
MacOS 10.15.7 as specified. Pro Tools 2021.6 as listed.
Old 06-24-2021, 01:38 PM
Exactly what I ask , but there is no this function on my Protools 2021.6?
File Type: jpg Screen Shot 2021-06-24 at 10.36.23 PM.jpg (30.2 KB, 0 views)
Old 06-24-2021, 01:46 PM
Are you on an Intel Mac?
Scott Gatteño
Old 06-24-2021, 01:51 PM
Ben Jenssen's Avatar
Also, not all intel processors have turboboost.
Old 06-24-2021, 01:54 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
The “Intel Turbo Boost” option is enabled by default for Intel Macs that support it. If you don’t see the option then your Mac doesn’t use Turbo Boost or doesn’t support disabling it. If you disable it (or leave it enabled), that setting persists for the entire system. In other words, it’s not Pro Tools specific. More info: https://resources.avid.com/SupportFi...ols_2021.6.pdf
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 06-24-2021, 02:13 PM
Kyle, my problem is not the function, it's the fact that it persists after Pro Tools is shut down. At least the enabling of Turbo Boost does. It stays on permanently, as far as I can tell.
Dominic
Intel Turbo Boost Max 3.0 Spyderrp7 Windows 8 07-14-2017 10:29 AM
I disabled Turbo Boost and Pro Tools seems more stable jacko Pro Tools 12 4 09-19-2016 03:52 PM
Windows 8.1 Config: Turbo Boost question 23audio Windows 8 08-27-2015 01:26 PM
Intel Turbo Boost causing problems with PT 9? Anyone know how it be turned off? Georgerob Windows 0 11-22-2012 03:13 AM
New Mac Pro Feature - "Turbo Boost" JSR Pro Tools TDM Systems (Mac) 10 03-06-2009 02:19 PM
