  #61
Old 09-30-2022, 03:59 AM
Default Re: More Carbon Sync Issues...Must Get Solved...
Originally Posted by martthie_08 View Post
Out of interest, was the bug fixed in the 2022.9 firmware for Carbon or in the 2022.9 Pro Tools software?
The reason for me asking is that my Pro Tools Carbon subscription expired Sep 10, 2022 to a perpetual license and the latest Pro Tools version that I have access to is 2022.7.
Given that the "promise" or ambition of a stand-alone app to update the Carbon firmware has not materialised, I think you'd be best to update the firmware with a copy of PT Intro (if that works with Carbon) or perhaps subscribe to a fresh copy of Studio for one month to get the latest firmware update.
There was definitely a Carbon firmware update as part of 2022.9, but I can't tell you what it did.
I imagine Avid would probably send you a copy if you asked nicely, anyway.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
  #62
Old 09-30-2022, 04:11 AM
martthie_08 martthie_08 is offline
Thanks Dominic, I've already upgraded the firmware as i am working in a different studio at the moment, which has 2022.9 ultimate. It will be interesting to see what happens when I connect it to the 2022.7 studio system.
  #63
Old 09-30-2022, 06:02 PM
jeffro's Avatar
jeffro jeffro is offline
...was the bug fixed in the 2022.9 firmware for Carbon or in the 2022.9 Pro Tools software...
It was a software fix in the Hybrid Engine (so benefited HD hardware as well). I started up a support case for you so please check your email and reply there as needed. Thanks!
linkedin
  #64
Old 10-01-2022, 03:01 AM
thanks for your reply and help, that's good to know!
I've also got a HDX system with Ultimate/Flex as my main rig, so that one will benefit from the fixed Hybrid Engine too..
  #65
Old 10-11-2022, 08:58 AM
jmkeane jmkeane is offline
Using Carbon with Latest PT 2022.9. It's still broken. Recording stems back into session via auxes results in random tracks being recorded out of sync. Significantly out of sync. 500 to 600 samples at 48k. Nightmare. I'm working in 5.1, laying back eight 5.1 stem tracks at once. I use the same process on my HDX rig everyday. No sync issues ever. Only difference is no hybrid engine being used in HDX system...
Macbook Pro M1, Monterey 12.6
  #66
Old 10-11-2022, 09:01 AM
just checking: did you update the Carbon firmware that came with this release?
  #67
Old 10-11-2022, 09:12 AM
Absolutely. Firmware update was completed.
  #68
Old 10-11-2022, 11:19 AM
jeffro's Avatar
Sorry to hear that! Started a case on your behalf to get more info and to track this.
linkedin
  #69
Old 10-11-2022, 04:42 PM
Thank you.
  #70
Old 10-27-2022, 03:47 AM
Burgher Burgher is offline
I am very excited about the Carbon Pre announcement and I am planning on purchasing 2x Units for a fully expanded Carbon system. However, I am concerned with the sync issues enough that I will be holding off doing this until it has been confirmed to be solved. I expect I am not the only person in this position. I think if they could get this resolved Carbon will be a phenomenal Pro Tools System.
Carbon Phase issues with hardware inserts alhardy Pro Tools | Carbon 5 08-10-2023 11:03 AM
Sync Problems with Carbon Downstream tomhartman Pro Tools | Carbon 7 07-01-2021 02:15 PM
Using Carbon with Avid Sync HD? akhafaji Pro Tools | Carbon 1 01-18-2021 12:03 AM
Radar II sync to Pro Tools ***Solved*** GuyPicks Pro Tools TDM Systems (Mac) 5 06-13-2008 09:04 AM
