Old 11-18-2021, 09:24 AM
EddieJones's Avatar
Default Re: EUCON 21.10.1 Released
Originally Posted by m4tune View Post
Eddie, can you please provide a way to get back to Eucon 21.6 on MacOs and IOS?
Can you please post what commands are not working, can you check the command looks OK in the Softkey editor?
Old 11-18-2021, 10:07 AM
m4tune m4tune is offline
I use the exact same commands as in the 21.6 version where everything worked perfectly.
This should create the first track preset from my user folder, for example:
shift + cmd + n
cmd + backslash + u (the command for up arrow from the list in the editor)
cmd + backslash + u
cmd + backslash + u
backslash + n (the command for Return from the list in the editor)
After the first line it hangs. Only the window for the new track dialog is on the screen.
Mac Pro 5,1 12 Core 3,46 GHz MacOs 10.15.7 (Catalina/Dosdude), 64GB Ram, Angelbird Wings x2, PT HDX, HD I/O, 2x 192i/o, 1x Digi Pre, 1x Red8Pre 2x Avid S1. Artist Transport, PT2021.6
http://www.4tune.at
Old 11-18-2021, 10:39 AM
EddieJones's Avatar
I just made this on my (Windows) machine and it works OK. I suspect a timing issue. Can you try adding a pause command in between each \a. I attached an example for another macro.
Old 11-18-2021, 10:41 AM
EddieJones's Avatar
Old 11-19-2021, 02:15 AM
reset studio reset studio is offline
Eucontrol 2021.10.1.29, the "Assignable Knob" function on Artist Transport still not work. Probably not fixed yet.
Old 11-19-2021, 03:59 AM
Cheesehead Cheesehead is offline
Oh wow, does this mean we now have pause commands for Eucon macros?
That sneaked out without me noticing.
Mac Pro 7,1 16 core, OSX 10.15.6, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2022.4
Old 11-19-2021, 08:20 AM
EddieJones's Avatar
The /a pause command has always been there. It's limited though and only adds a very short pause. We are working on a much better delay feature for the next release.
Old 11-19-2021, 01:18 PM
Hey Eddie,
Thanks for the tip with the delay "\a"
It made several key commands combinations work again…
But, I'm not able to get a nearly reliable performance as with v21.6…
This seems to be a workaround with a very shaky version of Eucontrol - v21.10… Sorry for being straight forward…but when will this be fixed in a sustainable standard?
http://www.4tune.at
Old 11-19-2021, 02:08 PM
EddieJones's Avatar
Hey Eddie,
There was a bug in Apples API we used for key commands which was causing crashes so in 21.01 we changed the way we do it. That caused other issues so we changed again. Unfortunately, we think this made it work a lot faster, so commands are firing off nearly instantly together. The only real solution is an adjustable delay....which we are working on for the next release. We are also looking at putting in an overall delay setting too so you don't have to enter a whole bunch.
Old 12-08-2021, 04:36 AM
cebolao cebolao is offline
so how about this "upper row mode bug"?
did you manage to replicate it?
EUCON 20.5.0 released EddieJones Artist Series 29 06-05-2020 06:16 AM
EUCON 20.6.1 released EddieJones Avid S4/S6 0 05-21-2020 10:30 AM
EUCON 20.1.0 Released EddieJones Avid S1, S3, Dock and Control App 44 05-08-2020 11:59 PM
EUCON 20.1.0 Released EddieJones Avid S4/S6 11 03-09-2020 11:35 AM
EUCON 20.1.0 Released EddieJones Artist Series 2 03-03-2020 07:31 AM
