Old 07-28-2021, 06:59 AM
[email protected] sleshnyc@gmail.com is offline
Default cmon Avid, it's time for hardware insert bypass
I mean, cereally. I still can't bypass a hardware insert for a/b purposes?
Old 07-28-2021, 07:20 AM
JFreak JFreak is online now
Default Re: cmon Avid, it's time for hardware insert bypass
You don't have bypass on your hardware? Seriously you would need to re-route the mixer for a hardware insert bypass from PT side. There is no magical invisible hand to replace your wiring with a hard bypass wire that would not interrupt PT mixer, but it would obviously make at least two clicks when you change your hardware insert to hardware bypass cable.
Just think about it for one second, you get it.
Old 07-28-2021, 08:30 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Why can't it work like any plugin insert? No need to re-route anything, just command+click on the insert for bypassing the I/O.
You can already control+command click to activate/deactivate the hardware insert, pretty much the same effect, but this cannot be automated. Previous PT versions had to stop playback when doing anything I/O related so maybe that's why bypass isn't supported.
Old 07-28-2021, 08:36 AM
Hardware Insert is delay compensated and therefore bypassing a hardware means taking it off the mixer, which means re-calculating delay compensation for the whole mixer.
Old 07-28-2021, 09:25 AM
umm no, not all hardware has bypass. I can barely understand what you wrote. All i'm saying is why can't i bypass an insert that is using external hardware the same way I can a plugin.
Old 07-28-2021, 09:51 AM
Because your track is being delay compensated by the amount the DA and AD takes time, so if you just magically re-route your mixer to connect your hardware insert send point to return point it will be out or sync, or it will stop playback for a brief moment due to having to rebuild the mixer. Neither outcomes are acceptable. The only way to bypass hardware insert is to do it on hardware side. Either pressing the bypass button on the box or having a short wire available for disconnecting the hardware box and replacing it with a wire that does nothing.
Old 07-28-2021, 10:10 AM
DontLetMeDrown DontLetMeDrown is offline
Janne, it still has an input and output and should be able to reconnect those when bypassed and yes I think the “industry standard” software should be able to ping that delay during setup so that it can compensate for it.
Old 07-28-2021, 10:13 AM
There are still laws of physics applied with anything external analog audio (DA and AD take at least one sample each). If you want a no-click hardware bypass it will result in screwed up latency compensation. If you want proper latency compensation it is just as much a clock than disabling the hardware insert. So why bother?
Old 07-29-2021, 09:31 AM
Dan IceWood Dan IceWood is offline
as annoying as it is....just regular bypass would mean that the interfaces had relay between each input and output that would just feed the signal in a loop - therefore deactivating IS BYPASS when it comes to HW inserts - annoying I know ,but is a hardware issue NOT a software one
Old 07-29-2021, 09:51 AM
Exactly. If we want a bypass to a hardware insert, as I said already, it will mean one of the two things: either latency compensation goes wrong, or there will be a stop in playback. Only way to have a good bypass would press a button on external hardware.
Using a Distressor as a hardware insert with Avid Omni & ProTools 11 HDX agrizzlybear Third Party Interfaces 8 03-20-2014 12:10 PM
External Hardware insert bypass lexaudio Post - Surround - Video 4 08-21-2013 03:23 PM
PT10.3, HD2 accel Avid I/0 Hardware insert issue? mattpgtr macOS 0 10-20-2012 10:52 AM
Hardware insert with non-Avid/Digi interface? ChuckS Pro Tools 10 3 03-06-2012 06:38 PM
PT7.3 I/O Insert Bypass MikeTrahearn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-07-2006 07:05 AM
