MTRX Studio, need more than 16 analog inputs
Hi Everyone,
Quick question: If I need more than 16 analog inputs (TRS) what is best/doable? buy another MTRX studio? and link it to the same HDX card on port 2 or do I need a second HDX card, In that case how do you link the two HDX cards when they are in a Thunderbolt 3 rackmount. Using another Thunderbolt 3 cable between the 2 TB3? Thank you all.
PC: Dell Precision T7920 CPU: Xeon 3104 @ 1.7GHz x2 GPU: NVIDIA Quadro RTX 4000 Ram: 80GB OS: Windows 11 Workstation, HW: Pro Tools | HDX TB3 MTRX Studio Bundle. SW: Pro Tools Ultimate 2023.12.1 Last edited by starlingmusic; 04-27-2021 at 08:22 PM. Reason: typo |
Re: MTRX Studio, need more than 16 analog inputs
A single HDX card can support up to 64 inputs and outputs so no, you don't need another HDX card (if you did, though, it would need to be in the same computer or chassis as the first card as they are connected directly to each other by a short TDM/SATA cable).
As an alternative to a second MTRX Studio you could use a MTRX with multiple A/D cards but, it may not work out any cheaper though.
https://lukehoward.com/ |
A lot of issues with your question.
First off, if you need more analogue inputs, then yes, another interface will be necessary (doesn't have to be MTRX Studio.) BUT.... you could also use the DANTE on the MTRX Studio to expand to more analogue inputs. There are plenty of DANTE to Analogue converters. As Luke mentioned, each HDX card supports 64 channels. If you were using the full complement of i/o on the MTRX Studio, that would require using all 64. If you aren't, you could only use 32 channels (one port) and attach a second interface for another 32. (However, if you use the DANTE mentioned above, you'd be using both ports again) As for multiple HDX cards -- depends on the chassis. No, you can't use multiple chassis with HDX cards in each of them. HDX cards have to be all in the same chassis. Sounds like you are using the Avid one that can only hold 1 HDX card. Sonnet and Magma both make chassis that can hold up to 3 cards. When multiple cards are in the same chassis, there's a little ribbon cable that connects the HDX cards together.
I suggest expanding it with Dante.
Products such as the Focusrite A16R, Ferrofish Pulse DX, Lynx Aurora Dante and others. You might want to think about going for something fan-less (Aurora and Ferrofish) but it is your call there. All you need to do is connect the devices to the same ethernet network and route them in Dante controller and they will turn up as Pro Tools IO. As stated, you have up to 64 channels to play with when using the MTRX Studio, and it will work with a single HDX card. If you need to expand beyond one HDX card (ie want more than 64 channels of IO) then you need to have the HDX cards housed in the same chassis, as they need to be connected together with a small, supplied cable. Quote:
James Richmond https://www.jamesrichmond.com 2019 Mac Pro, 2022 Mac Studio Ultra Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro. Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com Latest Article: Auto-Bounce for Logic Pro Affiliate Links: Auto-Bounce by Tom Salta Dreamhost Web Hosting Last edited by uptheoctave; 04-28-2021 at 06:20 AM. |
There are the optical converters as well. It has 16 channels of ADAT built in so those could be used with an analog front end. Some options out there for 8 channel mic pres that convert directly to ADAT.
• MacPro (4,1 to 5,1) 12 Core 3.46 GHz // 96GB // AJA Kona LHi // OWC Mercury Elite Pro Quad, USB 3.0, eSATA • PT HD|Native 2024.3 on macOS 12.7.4 (OpenCore Patcher 1.4.3 on Crucial SSD) • Avid Dock, iPad 7th gen & EuCon 2023.11 • DADman/Eucon monitoring • BSS (DAN + 100), QSC DCA 1644, JBL 7 Series • MTRX Studio // 7.1.4 www.quesound.com |
This will be the least expensive option :)
Or you can use Dante. Or you can use ADAT. ADAT is probably the cheapest way to go. But the HD I/O is the more Pro way to do it. Dante is the Future networking guru way to do it.
Justice C. Bigler www.justicebigler.com Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB 2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre Road/hotel: Roland OctaCaputre / Apogee One |
Thank you all for your prompt responses.
I think I'll go with a second MTRX Studio. I attached a drawing trying to understand the connections between MTRX Studio(s) and HDX Card. My understanding is: A1 to C1 B1 to C2 Do I need a connection between the MTRX themselves? again thank you for your help and for sharing knowledge ;-)
PC: Dell Precision T7920 CPU: Xeon 3104 @ 1.7GHz x2 GPU: NVIDIA Quadro RTX 4000 Ram: 80GB OS: Windows 11 Workstation, HW: Pro Tools | HDX TB3 MTRX Studio Bundle. SW: Pro Tools Ultimate 2023.12.1 |
Why would you buy another MTRX Studio? There's better and cheaper ways to do this.
MTRX Studio with HD I/O | nedd | Pro Tools | MTRX & MTRX Studio | 37 | 07-04-2023 04:58 PM |
MTRX Studio i/o | Cheesehead | Post - Surround - Video | 9 | 02-21-2021 08:17 AM |
MTRX Studio - AVB | [email protected] | Pro Tools | MTRX & MTRX Studio | 3 | 02-03-2021 02:32 AM |
Mtrx Studio DB25 Avid Cable for analog input | cerisaie | Pro Tools | MTRX & MTRX Studio | 11 | 11-16-2020 02:21 PM |
MTRX Studio question about analog inputs and line level | polyh3dron | Pro Tools HDX & HD Native Systems (Win) | 3 | 08-07-2020 12:23 AM |
