  #81
Old 11-16-2020, 03:34 AM
Default Re: Plugin Updates - Please Post Here!
Originally Posted by musicman691 View Post
If you look at the thread I linked to you'll find that someone who got in touch with Waves tech support said it was due to 5,1's not having Metal support in their video cards. I'm calling bullcrap on that - how many have upgraded their 5,1's to a Metal video card?
Well technically would be true with stock cards. Even though you have upgraded your card I believe there is anew spec for Metal 2, you might want to look into that.
Although, as we go into the future those computers are just going to get less capable and less compatible, especially one we've finally transitioned to ARM. Still, I imagine you have around 5 years to sort that one out. We all do!!
The Mac ecosystem will be better off in the long run as they will have less restraints and be able to develop their hardware, software and OS in tandem. It's a unique position for Apple software like Logic and Final Cut, they really stand to benefit from better performance and reliability in the long run.
  #82
Old 01-04-2021, 08:36 AM
Stephen Bond's Avatar
All of my products have updates over at Softube Central.
Stephen
Save an additional 10% off any purchase at Waves!
https://www.waves.com/r/9zsnwd
  #83
Old 02-18-2021, 07:17 AM
AmpliTube 5_0_2 is available!
I'm happy to report the plugin opens exponentially quicker than 5_0_1 in Pro Tools 😍
Changes from version 5.0.1:
Models
Fixed an issue that could corrupt audio processing when loading Rack effects before an amp
Fixed an issue that could corrupt White 2A behavior when inserted as a stomp effect
Fixed an incorrect sound response when loading a Leslie model on Cab 2 and Cab 3
Fixed a potential crash when setting Model delays to minimum value
Improved sound behavior on the Chorus-1 when inserted as stereo processor
Standalone
Improved iRig Stomp I/O Compatibility
Fixed an issue that could cause the application to crash when loading Projects with 96K Sample Rate
DAW: fixed zippering artifacts on tracks Tone Eq
Fixed an issue that corrupted external MIDI Control communications
Fixed a potential crash which may happen when closing the Audio MIDI project settings window
DAW Section: fixed an issue that could limit the project length
DAW Section: added tooltips on parameters
General
Fixed a potential crash saving a new 'Default' Preset
Fixed a potential crash when assigning a parameter via MIDI learn
Fixed an issue that would potentially crash the app when loading the Rack Parametric EQ as a stomp effect
Fixed an issue that was corrupting the Custom IR Cab settings
Fixed an issue that was corrupting the Audio MIDI project settings retention
Fixed an issue that was corrupting the Presets MIDI assignments retention
Fixed potential unexpected behavior when right-clicking on some model parameters
Fixed an issue that was corrupting the automation for Mic angles
Fixed an issue that was corrupting communication when a MIDI Controller was connected after AmpliTube launch
Fixed some inconsistencies when loading certain old presets that contained Leslie cabinets
Reduced plug-in scan time
Improvements
Preset Browser: added multi selection on folders
Preset Browser: added a refresh option
Added an ICON for incoming MIDI messages
Added MIDI Control for Tap Tempo
Added Scrollbar on the Chain Section
Improved parameter control via Track Pad
Tooltips: values can now be copy/cut/pasted
Improved GUI navigation feedback
General Reliability Improvements
  #84
Old 03-01-2021, 05:34 AM
All Softube plugins have been updated and are resizable!
I'm getting to like Softube more and more, save of course the high prices
Stephen
  #85
Old 03-02-2021, 02:39 AM
https://www.softube.com/support/change-log/2-5-13
Version 2.5.13, welcome to the new Empirical Labs products.
New products
Empirical Labs Lil FrEQ (also available in Console 1)
Empirical Labs Mike-E Comp (also available in Amp Room and Console 1)
Empirical Labs Trak Pak (Console 1 exclusive channel strip)
All products
Introducing resizable GUI:s for all products! VST2 in Cubase and Nuendo as well as AU in Ableton Live are currently not supported.
Made sure current loaded preset is recalled properly when loading a saved project.
Preset Collection: Fixed issue which could cause problems if you changed preset from the plug-in preset browser while Preset Collection was in group edit mode.
Online Manuals
Introducing online manuals for the Empirical Labs products.
Abbey Road RS127 Box, Abbey Road RS127 Rack, Abbey Road RS135, Acoustic Feedback, Spring Reverb, Tube Delay
Added HiDPI GUI.
Console 1
"Load Strip" now shows a list in alphabetical order in the On-Screen Display.
Added proper readout for Solo parameter.
Fixed a rare bug when changing the DAW:s max volume while running Console 1 DAW Control in VST3.
Fixed a rare bug that could cause a crash when changing back-and-forth to Apollo Central mode.
Changed update-rate of the On-Screen Display to make connected HW run smoother.
Fixed an issue that could cause Apollo Central mode to crash on start-up.
Improved handling of track selection with 3 Console 1 Fader units connected. Added lines below tracks in the On-Screen Display to indicate which tracks the HW controls.
Drawmer S73
Fixed an issue where automation was not available in mono in Pro Tools.
Focusing Equalizer
Fixed an issue causing the sliders to be too big on Windows.
Model 72 Synthesizer System
Fixed an issue causing modulation using velocity to be slewed from earlier values.
Fixed the level and envelope LED:s in the Amp Room Model 72 Filter.
Added parameter readouts for Model 72 modules in Modular.
Mutable Instruments Braids
Fixed an issue with uninitialised memory that would sometimes break the DSP-processing.
Weiss EQ MP
Fixed an issue were presets were not accessible in the plug-in preset browser for small window sizes.
  #86
Old 03-04-2021, 11:59 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Huuh. Are you using Mac or Windows?
I'm on Windows 10 and it's still as slow as it was befor the update on my system.
Christian D Hagen | I7 Builds | PT/OS Compability Chart
  #87
Old 03-05-2021, 03:58 AM
I'm on a Mac Chris.
  #88
Old 03-06-2021, 12:28 AM
Top Jimmy's Avatar
Oh my gosh! You can finally hide everything you don’t have license to. About time! They need to bring that to T-Racks.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
  #89
Old 03-06-2021, 04:21 AM
You mean it doesn't install everything regardless if you have a license or not? That'd be great.
Got an email a couple of days ago touting their new account manager s/w. Anybody tried it yet?
  #90
Old 03-06-2021, 05:06 AM
The IK MM Product Manager is a leap forward in many respects.
https://www.ikmultimedia.com/products/productmanager/
Stephen
HTML code is On
Where are the plugin updates? M2E AAX Plug-ins 6 01-06-2019 10:17 PM
Plugin Updates bcs723 VENUE Live Sound Systems 3 10-19-2008 07:36 PM
6.9 TDM plugin updates? jeremyroberts Pro Tools TDM Systems (Mac) 13 04-19-2005 11:11 AM
Plugin updates for 6.7 Fader Invader Pro Tools TDM Systems (Mac) 1 12-08-2004 05:50 PM
6.4 plugin updates FDurrett Pro Tools TDM Systems (Mac) 2 08-02-2004 10:33 PM
