Consolidation problem with 10.3.1
Hi having some problems consolidating some files, some files I imported into protools are wav files but likely not broadcast wav ie rendered sound design fx or recordings from my 744 recorder which are BWF. When I try to consolidate these the links are missing and the files fail to copy across. With the recorded files I had to specifically choose to consolidate the clip and then manually stretch them out to give them handles and then edit the fades back in which was painful.
It is truely bizarre, it simply cannot link the files, if i manually copy them over, and try to link to the files, by telling protools to search only within that session directory it will go and locate a file elsewhere where I originally placed them in a edit session. Also when I try to import files it will fail to copy them into the session audio files directly but link to where they originally are placed. I think it's a bug and a time consuming one to deal with. Any ideas ? |
Re: Consolidation problem with 10.3.1
FYI the only way for it to link properly when importing session data is to choose copy and not consolidate.
This is still happening with any files that are directly imported into the session. Protools doesn't copy these to the audio files directly initially also.
Elastic Audio consolidation problem | regrexion | Pro Tools M-Powered (Mac) | 16 | 08-31-2010 06:40 PM |
Consolidation | GloryIsSilent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 03-08-2009 02:55 PM |
Consolidation? | Rome630 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-18-2006 06:26 PM |
consolidation ? | jata | Pro Tools TDM Systems (Mac) | 6 | 10-16-2005 12:24 PM |
consolidation | sid rosen | Tips & Tricks | 2 | 11-12-2004 12:28 AM |
