Old 05-01-2012, 10:20 AM
alchemical.dream alchemical.dream is offline
Default MP 9 Recording; Timing Issue..
Hi, this has probably been covered but new to forum and having trouble searching.
I am experiencing big timing issues recording guitar and vocals into session that has multitrack drums already layed down. ( 6 tracks of drums )
I experience no latency while monitoring and recording, but on playback the newly recorded track is way behind the actual drum track ( by way behind I mean in milliseconds actually.. but the timing issue is clearly noticeable and can be seen clearly when zoomed into view audio )
I am recording by having an aux channel as my input, then routing this to a track (all within Pro Tools).. I have always recorded this way and had no issues when i was using my Digi 001 ( recently upgraded to MP 9 )
If I record direct to track there are no issues and the audio is in time.
I have changed H/W buffer to lowest rate.. tried without Delay Compensation and with.. and everything else i can think of..with/with out plugins ect.
It seems there is only an issue when I want to have an aux as input and then route it to track to record, I find this the best setup for adding effect/ compression ect onto track for recording.
what am i missing???? I know i can just record direct to track.. but I want to find out what is happening.
Any help appreciated.
crappy Compaq CQ56 laptop 1 processor
8 Gig Ram
M-audio Fast Track Pro/ MP 9
Old 05-02-2012, 12:47 AM
Default Re: MP 9 Recording; Timing Issue..
Ok
I seem to have solved the issue. By making the Delay Compensation long
but not having it enabled the recording lag has disappeared.
Seems a bit strange ?
anyway issue solved.
Recording timing / late recording issue resolved DAWgEAR Pro Tools HDX & HD Native Systems (Win) 0 07-17-2013 10:10 AM
Timing issue algy Pro Tools 10 4 04-30-2013 03:21 PM
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 08:57 AM
Timing issue when recording audio from MIDI tracks Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-16-2006 08:42 AM
5.3.1 timing issue? da BaSsTaRd! 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-23-2002 07:21 AM
