Just wondering if the new Fast Track Ultra 8R is compatible and works with Pro Tools M-Powered 8. I'm currently running M-Powered 7.4 with a FireWire 410. Also, will this new setup work on a Macbook (2GHZ Core 2 Duo, 2 GB RAM) with Leopard 10.5.4?
It's certainly supported(PT M-Powered, 7.4 cs3 or higher as well as Pro Tools 8).
I found the following issues in the support section with the Fast Track Ultra series and Pro Tools: Known Issue: Playback Stops With -6101 Error in Higher Sampling Rates With a Buffer Size of 128 Workaround:
Known issue: Audio Playback is Muted When a Click Track is Present With No Audio Workaround:
This should release the "mute" bug and allow normal use of the Fast Track Ultra with Pro Tools M-Powered. |
Multiple M-Audio Fast Track Ultra 8R in Pro Tools 10 | miki725 | macOS | 1 | 11-21-2013 09:00 PM |
Pro Tools 10 Audio Interface Setup- Fast Track Ultra | kwj3532 | Pro Tools 10 | 5 | 02-21-2013 11:55 AM |
Pro Tools SE Cant configure 8 separate tracks with M-Audio Fast track Ultra 8R | harleycummins | Pro Tools M-Powered (Win) | 2 | 02-21-2012 10:41 AM |
Pro Tools LE and M-audio Fast track Ultra | howbotnik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-16-2011 02:56 PM |
Pro Tools M powered freezes repeatedly with M audio fast track Ultra | sagarsarkar | Pro Tools M-Powered (Win) | 0 | 01-03-2011 01:34 PM |
