Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 08-11-2008, 11:18 PM
Jeff E Jeff E is offline
Default Firewire vs USB interface
I have been looking at adding an interface for my laptop. The Mbox 2 will suffice but the pro is firewire. IS one better than the other? Is one more stable?
Thanks
Jeff
Old 08-12-2008, 07:16 AM
JChance JChance is offline
Default
As a general rule, firewire is the better choice. Because it transfers data a gazillion times faster than USB 1.1 (which is what the standard mBox interfaces are), you are normally able to use much lower buffer settings for reducing latency when recording. Plus, most firewire interfaces have bells & whistles that the USB units do not. Many of them have digital or s/pdif inputs & outputs, and usually allow for recording & playback at higher sample rates.... Again reducing latency.
With an mBox and a reasonably up-to-date computer, you would be fine for recording a track or two at a time. So it's perfect for singer/songwriter types who want to record a guitar or keyboard/vocal demo.
Firewire interfaces can normally record several tracks at once, depending on the rest of your setup. It really just comes down to a matter of your uses.
If you are looking to record scratch instrument/vocal demos or want to do 1 or 2 track overdubs, an mBox would probably suit you fine.
However, if you want to be able to record with the lowest latency possible, and/or want to record at sample rates higher than 48K, then firewire is the ticket every time.
Good luck-
8ch FireWire or USB Interface w/ PT MP9 Rjones17 macOS 5 12-14-2012 09:06 PM
Problems with PT9 and FireWire interface FT13 macOS 5 12-28-2011 10:38 PM
1 interface, 1 hard drive, only ONE firewire interface? beyoutofull1 Pro Tools M-Powered (Win) 5 11-22-2010 05:08 PM
firewire interface kav 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-01-2004 09:26 AM
96kHz FireWire Interface Tone Pro Tools TDM Systems (Mac) 16 12-19-2001 01:52 AM
