Old 07-29-2006, 09:51 PM
PTGuy PTGuy is offline
Default Couple of pan pots stuck and master fader fighting
On channels 14, 16 and 17 the pan pots do not work. I have tried switching them from pan to insert and back and forth and they will just not change any data. Also every once in a while the master fader will fight me and will not let me set the level via the D-Command. I have to change it via software on the screen. Then a few minutes later I can control it with the fader again. Also there are times when I have over say 28 tracks that the master fader will not show up on the D-Command at all even with banking through tracks. You can see all of the other tracks but the master. Very frustrating.
Old 07-30-2006, 02:38 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: Couple of pan pots stuck and master fader fighting
Sounds to me like you need to go into the utilities pages and fool around with the tests.
Not that that will be a guarentee to fix your problems but it should tell you more of the natture of them.
- do the pots respond to the 'touch' test for example
- there's a frequency indication in the test pages ... are the frequencies on the broken ones very different from the ones that do work ?
stuff like that.
Same for that fader really.
Chris Lambrechts
Applications Specialist- Live Sound
Old 07-31-2006, 11:38 AM
Ok I went into the test page and the two rotarys that are not working are highlighted in the scribble strip. Any idea on this Digi? I even did a reset and nothing changed.
Old 07-31-2006, 02:12 PM
time to contact your dealer and get him onto it imvho. While all this kinda sux in a unit like yours I can guarantee you that digi's Icon support and field service absolutely kicks rear ends ..... if there IS some fault in your controller it will be taken care off in the shortest possible delay. Get your dealer onto it ... quickest way to get things sorted out.
Good luck.
Chris Lambrechts
D-Command Master fader stuck in Inserts mode Jambroch ICON & C|24 2 12-17-2012 12:23 PM
Fighting fader?!?!?!?! Say WHAT?!?!? midafari ICON & C|24 12 09-30-2012 02:29 PM
Calibrating Trim Pots, Pots not responding D-Street Pro Tools TDM Systems (Mac) 9 09-04-2010 10:01 AM
Digi TS, fighting fader problem hitp ICON & C|24 4 09-22-2008 01:18 PM
Command 8 fader #4 fighting me!! elkpantscamino ProControl, Control|24, Command|8 1 08-16-2007 10:35 AM
