Avid Pro Audio Community (https://duc.avid.com/index.php)
-   General Discussion (https://duc.avid.com/forumdisplay.php?f=3)
-   -   Let's hear your latest stuff....right here (https://duc.avid.com/showthread.php?t=60365)
IntelDoc 04-19-2005 11:14 AM
Re: Let\'s hear your latest stuff....right here
No the 3000 will be fine for acoustics. Better than the others. I just thought that was what I was hearing as far as mics are concerned. I always double mic acoustics. The last song I posted actually had 4 mics on the guitar. Made them play it twice and panned all the tracks (8 total) to the left and right respectively.
The BF76 is a great plugin to use and learn - so YES learn it. better and worse... all how you use it.
HATE THE PODs so no comment there.... :-)
The benefit about Busses is that you can have multiple tracks send to the BUSS and use that effect to different degrees. I think that you are misunderstanding how to send to it? maybe not, but....
1. Create a STEREO AUX track and put a reverb on it.
2. Make that INPUT on that AUX track be BUS 1/2
3. Take your guitar track (say solo guitar) and send it with a BUS, not the TRACK OUTPUT to BUS 1/2. ( A separate Fader should come up for control.
4. Raise the initial AUX track (reverb) to 0bd. Control click the Solo button to SOLO Safe the track. That way it is now always on when you solo tracks. This is good because if you are listening you want to hear all the effects on the track. Try it unsafed and you will see what I
mean.
5. Now take the BUS (send) level and start to raise it... You will hear the reverb appliying itself to just the guitar part.
6. Continue to do this with all the tracks that you think need that verb and adjust the levels to taste.
That is using an effect on a BUS and applying several tracks to the same effect. Why is this good....? REVERBS TAKE UP HUGE AMOUNTS OF CPU POWER.....
Better ways to manage your mixes and CPU power.
Usually the FX that I know will be across the board are added ina BUS. You have 16, so use them wisely... I DO NOT make Compressors go to a BUS, but it can be done. I tend to have a long tailed reverb, a short reverb, a 2 tap delay and some other secrets taht I put into the mix. A lot of my verbs are sent out to hardware verbs (Lexicon PCM-90 and Eventide H-3000) but I still use a couple custom settings that I made in TrueVerb. All depends on the mix.
Hope this helps?
- Doc
Roy Howell 04-19-2005 03:10 PM
Re: Latest Stuff...
Paul Curtiz and I wrote this song a while back, and I just remixed it. Paul wrote the lyrics/melody and sang the vocals, and I did the music. Thanks for listening...
-Roy
Paint the Desert Wind
bigbolo 04-19-2005 11:54 PM
SiSoftware Sandra
System
Host Name : MINI-ME
User : Owner
Domain : MSHOME
Processor
Model : Intel(R) Celeron(R) CPU 2.60GHz
Speed : 2.60GHz
Performance Rating : PR2858 (estimated)
Type : Standard
L2 On-board Cache : 128kB ECC Synchronous, ATC, 2-way set, 64 byte line size, 2 lines per sector
Mainboard
Bus(es) : ISA PCI PCMCIA CardBus USB
MP Support : No
MP APIC : No
System BIOS : Dell Computer Corporation A03
System : Dell Computer Corporation Inspiron 1150
Mainboard : Dell Computer Corporation 0F3553
Total Memory : 767MB DDR-SDRAM
Chipset 1
Model : Dell Computer Corp 82852GM/GME/GMV/PM, 855GM/GME Montara Host-Hub Interface Bridge (A2-step)
Front Side Bus Speed : 4x 100MHz (400MHz data rate)
Total Memory : 768MB DDR-SDRAM
Shared Memory : 1MB
Memory Bus Speed : 2x 133MHz (266MHz data rate)
Video System
Monitor/Panel : Default Monitor
Monitor/Panel : Plug and Play Monitor
Adapter : Intel(R) 82852/82855 GM/GME Graphics Controller
Physical Storage Devices
Hard Disk : ST93012A (28GB)
CD-ROM/DVD : HL-DT-ST RW/DVD GCC-4243N (CD 24X Rd, 24X Wr) (DVD 3X Rd)
Logical Storage Devices
Hard Disk (C:) : 28GB (21GB, 76% Free Space) (NTFS)
Swordfish (D:) : 6.6GB (UDF)
Peripherals
Serial/Parallel Port(s) : 1 COM / 0 LPT
USB Controller/Hub : Intel(R) 82801DB/DBM USB Universal Host Controller - 24C2
USB Controller/Hub : Intel(R) 82801DB/DBM USB Universal Host Controller - 24C4
USB Controller/Hub : Intel(R) 82801DB/DBM USB Universal Host Controller - 24C7
USB Controller/Hub : Intel(r) 82801DB/DBM USB 2.0 Enhanced Host Controller - 24CD
USB Controller/Hub : USB Root Hub
PCMCIA/CardBus Controller : Texas Instruments PCI-1510 CardBus Controller
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : Synaptics PS/2 Port Pointing Device
MultiMedia Device(s)
Device : SigmaTel C-Major Audio
Communication Device(s)
Device : BCM V.92 56K Modem
Power Management
AC Line Status : On-Line
Battery No 1 : 100%
Operating System(s)
Windows System : Microsoft Windows XP/2002 Home (Win32 x86) 5.01.2600 (Service Pack 2)
Network Services
Adapter : Belkin Wireless 54Mbps Notebook Adapter
Adapter : Broadcom 440x 10/100 Integrated Controller
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
hey inteldoc...CAN U HELP ME PLS> i need to know outside the chip(which i know needs to be changed) what else can i do w/ this to make it my mobile center or should i not even bother. ill put the skematics of my desktop on here in a minute. hopefully u can give me some info. i can't record on my laptop cuz it freezes but i know its the chip i just wanna know what else needs to be done or just leave it alone.
Roy Howell 04-20-2005 12:27 AM
Interesting lyric.
JonnyGinese 04-20-2005 08:49 AM
hey people, here is some of my work I've done in the last week... and my studio isn't even setup all the way yet.
This is the bands myspace.com page
http://www.myspace.com/meetsthesky
they are pretty darn good and I'm booked to record a full length for them this summer.
Jonny
p.s. what do you think?
IntelDoc 04-20-2005 09:29 AM
I'd say that you have a good start, but it is really, really hot... Not sure if that is intentional, but it sounds too hot and is distorting.
Not bad though.
- Doc
JonnyGinese 04-20-2005 10:26 AM
yeah.. well I Mastered that the best i could the volume of it was like -5db when i got it from them and it already had pops adn cracks in it. that was my first attempt ever at mastering something. and also thast liek a 96k stream .. adn i dunno whta the MP3 is but unless its 320 it amkes the kick clip out.
Jonny
IntelDoc 04-20-2005 10:37 AM
Understand... I was not riping on it, just stating some stuff. Not trying to upset. The song was pretty cool though. I am working with a band like that tonight actually. Just finished up a project and am pressing to the next. This month it seems that I have a lot like that.
- Doc
skyking 04-20-2005 12:16 PM
i had this old Gretsch archtop givin to me years ago and never really played it till recently....heres a little swing tune i used it on and thought it sounded pretty cool for the old beater that it is...theres a pic of the guitar on the link also.........chas
http://user.cybrzn.com/skyking/
bigbolo 04-20-2005 08:17 PM
Re: Mac Mixes!!!!!!!!
hey i wanna know if i bought a minimac and maxed it out will that be enough for mbox protools cuz goin thru the [bleep] of gettin all types a components for a [bleep] computer just to work ptle. let me know pls cuz im goin mac and im thinkin about the minimac.
