Re: Overnight Lows
Joz |
Re: Overnight Lows
Re: Overnight Lows
got a new one here:
www.myspace.com/krou it's called "Bonk!" Simple dance tune, gritty, raw, with a weird twist in the middle, hope you like... |
Re: Mac Mixes!!!!!!!!
got a new one here:
Re: Overnight Lows
You have to use the same comp and EQ to avoid phashing effects. And if you add other plug-ins to the first track, add them to the second as well but bypass them on the second track. Joz |
Re: Overnight Lows
Thanks for the tips Joz, that is a hell of a lot of compression man but it sounds awesome! Might not be a bad trick for things like kick drums also. when are you guys going to be hitting the road on tour with this stuff man?
Flashes
Ok this is my first session with recordings from my new guitaramplifier , a Crate together with a Celestion 85 Wt. speaker. Recorded with some A10 mic from Shure.
Flashes Looped recorded guitars through Reason samplers + added some Zappa samples. All in all some midi fiddling w/controllers. Glorified clicktrack for drums but it's getting more meat now . Upped the 60-200 Hz range somewhat in Cool Edit Pro as well as the 4-6 KHz range. Any comments/criticism welcome. Walther Voideco |
INDEPENDENT!!!!
ok folks got some new tracks up. mainly instramentalz from InstraMentalz. let us kno wht u think of our beats! Peace! |
INDEPENDENT!!!!
ok folks got some new tracks up. mainly instramentalz from InstraMentalz. let us kno wht u think of our beats! Peace! http://www.soundclick.com/instrament...sentertainment |
Re: Let\'s hear your latest stuff....right here
Wonderfall: Just listened to your first track again on a better set of speakers and actually I think that the mix sounds pretty good now man. I think that the set of speakers that I originally listened on just didn't do the mix justice man. Excellent work on that track though. Now that I am listening in the studio, I hear what you mean about the dynamics.
