Did something by accident...now I can't hear a track
All three tracks were working OK, but now the middle (Inst 2) track has changed color and I can't hear it (see images):
Edit Window Mix Window Must have accidentally clicked on something, but the settings all look the same for all 3 tracks. I'm sure it's something simple, but what? PT 8.05 on Win XP. Cheers. |
Re: Did something by accident...now I can't hear a track
Your Edit window indicates that the MIDI data has no "destination". Your mix window, however, is not showing the "Instrument" section. Show the Instrument section in your Mix window and make sure that the MIDI out is set to the loaded VI.
View>Mix Window Views>Instruments
This will reveal the instrument routing at the top of that instrument track in the mix window. Check your MIDI routing to be sure the MIDI in that track is routed to the instrument on that track. |
That did it - thanks! Would have taken me forever to find it. Must have accidentally hit some key combination to turn it off initially...
