24 fps to 23.98
I've mixed a very detailed project at 24fps and the video got turned in for color correction, etc and converted to 23.98fps before I turned my mixes in. Is this gonna cause a problem? Will my mixes drift? Thanks
Re: 24 fps to 23.98
Re: 24 fps to 23.98
Thanks Tom - That sounds familiar - I know I've done this before, but can't find my notes. Could you be more specific as to the steps to take? Thanks! Eric
Re: 24 fps to 23.98
Re: 24 fps to 23.98
Create blank session
Set Frame rates (TC and F+F) to 23.98 Import Session Data from your edited/mixed session Check the Apply SRC box on the Right hand side of Import Session Data Tell PT that the session you are importing has material at a sample rate of 47952 Once imported make sure to reset the placement on the timeline so that your sync pops (and consequently all other material) line up with the 23.98 picture correctly. |
Re: 24 fps to 23.98
