ezdrummer & ezplayer issues in PT 8?
Anyone else having issues with Toontrack products(ezdrummer, ezplayer pro & Superior) in PT 8? The seem to work fine but the UI is jacked up.
b |
Re: ezdrummer & ezplayer issues in PT 8?
Yeah. Superior 2.0 has acted a little laggy in PT8. The master volume becomes unresponsive, the volume will change but the UI will not show it for a while. This also happened with the midi learn button.
J |
yeah, the UI is screwed up a bit :(
(EZ drummer) |
http://duc.digidesign.com/showthread.php?t=235067 |
Hi
A workable, though short term, fix for UI issues for all Toontrack products appears to be removing the instrument from the instruments panel (do not delete the track - keep that and all of your ez/midi regions). Then add it the instruments panel again. When you open it everything will be fine and you will have full use - until you close and reopen - the UI issues will return, so then do the same again. It takes a matter of seconds to remove and then re-establish and, although not fully ok, it is better than having all of the issues or no function at all. Hope this helps. Julian |
Are you using
v1.1.1 or v1.1.6 ??? |
i've been using it a lot recently but i've noticed the UI will get laggy and stuck but once i close it and open it it will work fine but every time i open a session it bugs out on me. honestly i've been having so many issues with 8 it's been unreal although in theory if it worked 100% i love the new features and it kept me from switching to logic at first.
http://www.toontrack.com/helpdesk/is...rtal.asp?ID=39
