Post fader inserts.
Since avid seems to be moving in motion slowly, I have a HUGE request for post insert faders.
As I bounce between PT and 32c, the latter gives me that function. How I use is, I place set my faders at unity and set my summing unit of choice to match 0db. So as I crank up the fader it drives into my summer or plug-in color of choice. Gives me that console drive. Sent from my iPhone using Tapatalk |
Re: Post fader inserts.
deleted
I’ll repeat it again. Since AVID is starting too WAKE UP, I have a request that I would love implemented. Sent from my iPhone using Tapatalk |
deleted
Inserts on Master tracks are post fader signal flow. If you want to drive audio into an insert, this is one way to do it.
I’ll post a video on this later.
Just found out a few other daws have post fader inserts also Sent from my iPhone using Tapatalk |
In the mixer in Mixbus 32c the fader is presented as a channel insert so you can place plugs in front of or behind it in the signal chain. You can also drag the fader insert to a new position. Some find this useful. DP also supports pre and post fader plugs on mixer channels.
YES! and I love that feature a lot. Sent from my iPhone using Tapatalk |
Plays havoc with delay compensation and automation though...... |
