IO setting
as IO output, I can choose between out 1-2 and main output. What are the difference ? What should I use for a bounce ? :confused: |
Re: IO setting
Impossible to say without knowing what interface you're using.
What he said.
In general that will be the same "final" output buss you're listening to unless you want to print something else than what you were monitoring. |
Re: IO setting
my interface is Eleven rack. |
Re: IO setting
Outputs available in PT with an 11Rack
main output reamp output digital output Within each of those there are outputs labeled 1 and 2. Those are if you want to output a mono signal. Generally you'll want to use the main output for a stereo output. Strictly speaking bounce doesn't care what the output is because you can always change what outputs the bounced file is using after the fact. But just to be safe set the output as main output and you should be good to go. |
Re: IO setting
Thank you MusicMan
