Avid Pro Audio Community (https://duc.avid.com/index.php)
-   Pro Tools 2020 (https://duc.avid.com/forumdisplay.php?f=160)
-   -   Crashing after BTD (https://duc.avid.com/showthread.php?t=410843)
Davidwilson 06-20-2020 11:42 PM
Crashing after BTD
Hi
Having an issue where 80% of the time after bouncing to disk PT 2020.5 crashes then re opens.
Anyone have a solution to fix this?
musicman691 06-21-2020 03:29 AM
Re: Crashing after BTD
System specs?
Davidwilson 06-21-2020 02:07 PM
What specs do you need.
I have Windows 10 with an I9 precessor.
Darryl Ramm 06-21-2020 02:20 PM
Nobody here can just guess what the problem is.
Plugins and corrupt sessions are always suspects for cases like this.
You need to just run through standard troubleshooting steps.
What extra details? Well just about anything compared to the info you gave. Start at “help us help you” up the top of each DUC web page. Include Versions of stuff you are running, A SiSoft Sandra report, what troubleshooting you have done, are you bouncing real time or not. Any difference with real time or fast bounce? What file system/device are you bouncing to? What changed? When did this start happening? What are you bouncing? What output format etc. (Stereo wave?) what if you try other output formats?
Your troubleshooting (before posting more info) should especially try trashing prefs, trying other sessions, testing with a new empty session, moving all .aaxplugin files out of the plugin folders, trashing prefs again, trying from a new user account.
