Really Stupid Question
I'm afraid to ask this. But here goes anyway: I'm interested in getting a Digi 001 Factory Bundle to record audio. But could I also plug a record player or tape player (I have the cables and a phono preamp)into the interface so I could record records and tapes and make them cd's? I would like to do both instrument and prerecorded audio mixing and would prefer not to have to buy two interfaces to convert the audio. Would I also have to buy a soundcard like a m-audio delta?
Thanks in advance |
Re: Really Stupid Question
You can easily record in to protools from those sources, the 001 comes with soundcard & in/out box. But you will need some other software to actually make cds, like toast or masterlist.
iTunes is software bundled with recent Macs which can burn basic audio CDs - it's what I am using for one-off disks for rough mixes. So easy to use it's pitiful.
For old LPs etc. an advantage of iTunes is the easy organisation of songs in a database, grouped by playlist (=LP) - Sean |
Why are we people so interested when reading "stupid question" ??? [img]images/icons/tongue.gif[/img]
I think I have to check every time to see if some DUC members think they are dumber than my stupid self [img]images/icons/smile.gif[/img] |
I'm drawn to them because if the question is stupid enough, I might actually know the answer. [img]images/icons/wink.gif[/img]
When you connect your record-player there are some issues....you have to convert the audio using a riaa-converter. I think with some eq-ing in ptle you will get some of the work done, but it may be simpler just to hook up the record-player to your amplifier and connect the tape-out from your amp to the digi001. Or buy a seperate riaa-converter (i think something like 30$...)
