PT 8 crash (AppHangB1)
Hola!
I need find a solution to this problem: I happends allllll the time, I think 4 or 5 times a day... The problem is that pro tools crash and windows 7 show me this information: Description: A problem caused this program to stop interacting with Windows. Problem signature: Problem Event Name: AppHangB1 Application Name: ProToolsLE.exe Application Version: 8.0.3.258 Application Timestamp: 4b8f028c Hang Signature: 39b8 Hang Type: 0 OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 11274 Additional Hang Signature 1: 39b82b1a8e7b43cdf2f3487f22f803c7 Additional Hang Signature 2: 4354 Additional Hang Signature 3: 435404ca48661b6334797df5b9ea85f8 Additional Hang Signature 4: 39b8 Additional Hang Signature 5: 39b82b1a8e7b43cdf2f3487f22f803c7 Additional Hang Signature 6: 4354 Additional Hang Signature 7: 435404ca48661b6334797df5b9ea85f8 I don´t know how to fix it, I copy down a sandra report, I have configurated my pc following the Digi web page information (windows 7). I use Texas intruments chip (1394)and I have a vienna key (Vsl Products) I don´t have Ilock drivers installed. Pro tools le 8.03 cs2, windows ultimate 7 x64(IE8 disable), Digidesign 003 RACK. SANDRA REPORT SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : WORKGROUP Host Name : lamandolina-pc User : La Mandolina Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Asus P6T BIOS : AMI 1201 02/24/2010 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DIMM DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Chipset Model : Intel Core CPU Generic Non-Core Registers Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Total Memory : 6GB DIMM DDR3 Memory Bus Speed : 2x 536MHz (1GHz) Memory Module(s) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce 9800 GT (2x 112 SM4.0 1.4GHz, 2x 512MB DDR3 2x900MHz, PCIe 2.00 x16) Graphics Processor Adapter : NVIDIA GeForce 9800 GT (2x112SP 14C 1.5GHz, 2x512MB 2x900MHz) Adapter : NVIDIA GeForce 9800 GT (2x495.6MB 2x900MHz) Storage Devices WDC WD5000AAKS-00D2B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) (F:) WDC WD5000AAKS-00D2B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (E:) WDC WD1001FALS-00E8B0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (D:) (H:) KingstonDataTraveler 2.0 4GB (USB) : 4GB (I:) ATAPI iHAS122 A (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 695MB (G:) Logical Storage Devices SISTEMA 1 (C:) : 146GB (NTFS) @ WDC WD5000AAKS-00D2B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) LIBRERIAS 2 (E:) : 466GB (NTFS) @ WDC WD5000AAKS-00D2B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) DISCO 3 (D:) : 834GB (NTFS) @ WDC WD1001FALS-00E8B0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Removable Drive (I:) : 4GB (FAT32) @ KingstonDataTraveler 2.0 4GB (USB) LIBRERIAS 1 (F:) : 319GB (NTFS) @ WDC WD5000AAKS-00D2B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) PROYECTOS 3 (H:) : 98GB (NTFS) @ WDC WD1001FALS-00E8B0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) 3.5" 1.44MB (A:) : N/A Audio CD (G:) : 0bytes (CDFS) @ ATAPI iHAS122 A (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13h Audio Device : ASUS HD Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : ASUS 3403h FireWire/1394 Controller 2 : TI XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Peripherals Media Player : Kingston DataTraveler 2.0 (3.73GB) Network Services Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Re: PT 8 crash (AppHangB1)
Most likely has to do with you have 64-bit OS?
A few things to try.
Try starting PT with only the the PT included plugins. or no plugins "shift" at startup Would help to post a list of which third-party plugins you are using. Install the latest iLOK drivers? People have had trouble with Nvidia cards, you cound try uninstallling the Nvidia drivers and using the windows generic driver. |
Thanks for the advices!
I use only altiverb and vienna ensemble pro plugins, I knew that it was better not to install LOOOOTTTS of plugins, about nvidia cards, do I need to download drivers from the net?? I found that working with vienna ensemble pro, PT works better than loading allllll the libraries on It, I have just this bug and I really want to fix it, I louse a lot of time rebooting the pc and loading all the samples into the ram... (I am composing a film score right now and every saved minute is important..) A few months ago (when I began to use PT) I used to have a 3 or 4 seconds delay when I played PT with video tracks...I solved it changing the default audio device (windows audio), I think perhaps It is conected with Nvidia drivers problems..could it be? do you know which are the nvidia drivers problem??? I have change to standard VGA Graphics adapter but the screem resolution is really bad,,,,I uninstall all nvidia drivers but still can choose Geforce 9800 GT (microsoft corporation - WDDM v 1.1)...are these the generic divers ????? Do you know another configuration for nvidia problems??? Thanks! Pablo |
