MBox / ProTools Trouble...
I'm new to recording and I've just recently set up an MBox with the included ProTools 6.4. However when I try to play anything back, it often stops and says that "Audio processing is conflicting with other CPU tasks". I have updated ProTools, ended every non-necessary process, and tried every option presented in the manual. I'm running XP Pro, an Athlon 64 3200+, a gig of ram and a 200GB DiamondMax Internal HD. Is my computer insufficient for ProTools? Will getting an external Audio-only drive help this? Thanks alot, Chris.
Re: MBox / ProTools Trouble...
Are you using a lot of plugins in the session you are trying to playback?Also set "Open ended Record allocation" in preferences to 10 minutes.
no, im not using any plugins.
Have you set your CPU usage in PT's to 85% and changed Open Ended Record Allocation?
yep. in the system usage window it doesnt ever get past about 10%.
I mean have you set both those preferences?If so,do you have all antivirus and crap disabled.What about other soundcards and what is your video card?
ive tried it with my LAN disabled, firewall disabled, Anti-virus disabled. Video card is an ATI Radeon 9800 Pro 256, sound is an audigy 2 ZS. ive disabled the sound card too, still no difference.
and yeah, i set both of the preferences. |
Primary culprits can be ( after regular tweaks are done ) the onboard audio device, and the NIC..
Disable, and try again... |
I've got a SOYO CK8-Dragon Plus Motherboard in right now with the nForce 3 chipset overclocking at 200mhz. would i get better performance out of an Asus K8V SE deluxe?
Try posting your query ; Here >>> Allen is the Guru... good luck, |
