PT 12.6 HD and the 003, will it work?
I'm planning on upgrading to PT HD 12.6 and I see on Avid's site it IS qualified for use with the current HD 12 software.
If the 003 will not operate with PT 12.6 HD I would not have a way to monitor without going to an S3 or 3rd party monitoring system. Can anyone at Avid let users of PT 12.5.2 standard and 003 hardware know what to expect if we upgrade and spend the $1899? Thanks! |
Re: PT 12.6 HD and the 003, will it work?
I'm on Yosemite with 12.5.2 and the 003 is working great.
So are you running both? Perhaps native with a 003? Can you please list full specifications of your system? |
Can you provide a link where Avid says PTHD supports the 003? |
Just to clarify I'm talking about running HD stand alone with the 003. Which currently you can not do without a qualified piece of HD hardware plugged in Not true. Running 12.4 HD on Win 10 with zero issues. |
Down at the bottom: http://avid.force.com/pkb/articles/e...m-Requirements |
You haven't needed HD hardware to run the HD software for years, since version 9 of Pro Tools. Same time the opened up Pro Tools LE to third parties. It has been compatible with any Core audio or ASIO device. Im using a 003 with PT 12.5.2 and 12.4; and have been doing so since Pro Tools 10 HD. As long as your audio interface is seen by your operating system, you should be able to use it in Pro Tools HD. Before now the only "official" way to get the HD software standalone was to have the complete production toolkit and upgrade to the standalone HD software. You have HD software installed on your computer, as Pro Tools only had a single installer. You just need the HD asset on you iLok to unlock the additional features.
