live recording 48 khz
hi
Can I you use 48 000 khz for the concert? after the concert I will mix it peace mac book pro Digi 002r |
Re: live recording 48 khz
It would be better to record at 24bit-44.1KHz and then dither down to 16bit-44.1 when your at the end of the mix/master process. If you leave the sample rate at 48KHz then when you go to play it in a CD player it will play slow.
Cheers |
Just curious but why would you want to record at 48k? Are you going to a video? What is your release format?
I got it 41 khz 24 bit thanx all peace |
