Pro Tools Problem?
Ok, so I finally got around to setting up my guitar (and Eleven Rack editor) and I installed ProTools 11 loaded it up was pleasantly surprised by how fast that occurred, and created a brand spanking new Full Session PT file, but, there had to be a but :-), when that looked like it was done a dialog popped up saying:
"The current playback engine does not support a sample rate of 48kHz" with just an OK button. Clicked on it and just go a blank screen. So I then tried opening the session just created and sure enough an error message dialog came up. So, what do I have to do to get a new file up and working. EDIT: My brother found that I had to change the session parameters to 44.1 kHz and things seems to be opening correctly now. The next step it go get something recorded :-) |
Re: Pro Tools Problem?
The 1.1.7 driver for the Eleven Rack is kinda wonky sometimes. It should switch automatically to your session parameters but sometimes it doesn't.
Glad you figured it out. Go make something cool bro. :cool: |
