Help Using De-Noiser.
Hi people,
I'm recording an acoustic (kind of unplugged) album and i'm recording lots of mics at a time, and i also get a lot of room ambience (noise most of the time). I came to use the plugin called RayGun and i'm impressed with the results but the question is... is there any big problem in using de-noisers, does it dostroy the sound in any way ??? [img]images/icons/confused.gif[/img] And by the way, if you had to use them, would you do it track by track, or as an insert in the master fader ?? [img]images/icons/confused.gif[/img] Thanks. [img]images/icons/smile.gif[/img] |
Re: Help Using De-Noiser.
Absolutely track by track. Does it destroy the sound in any way? You can just listen yourself.
Z |
The best advice I can give you on that is just to do what sounds best to you. Trust your ears, they can teach you stuff.
