How \'bout this one?
Looking at this system. Any compatability red flags? Thanks much.
Manufacturer Specifications: http://www.acerpanam.com/synapse/for...ords=&areaid=7 Specific Configuration: http://www.tigerdirect.com/applicati...Tab=2&NoMapp=0 |
Re: How \'bout this one?
A few.
Integrated Video is usually not recommended for Pro Tools systems. You never mentioned which interface you were planning on using it with, but if it is any of the PCI card products, the answer is definitely no. It uses an nVidia chipset that isn't in the list of supported ones on the Compatibility page. That doesn't necessarily mean it won't work, but it does mean that if you have problems, you are on your own. |
I use nVidia and have never had a problem. But I also use usb hard drives and have never had a problem there either. So sometimes it's just a matter of luck I guess. But you're on your own with that one.
