Avid Pro Audio Community (https://duc.avid.com/index.php)
-   003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) (https://duc.avid.com/forumdisplay.php?f=15)
-   -   -6085 Error?? (https://duc.avid.com/showthread.php?t=202329)
teacherman 07-29-2007 03:56 PM
-6085 Error??
Just upgrade from an old MBox and PT 7.0 to new MBox Pro and PT 7.1.3.
IMac OSX 10.4.9.
Now, I get a -6085 error when attempting to record and/or playback.
Any clues to resolve this?
thanks.
Avid 07-29-2007 05:27 PM
Re: -6085 Error??
There are a number of possibilities, try the search tips from this Quick Link in the Support section:
DAE Errors & Search Tips
http://www.digidesign.com/index.cfm?...4&itemid=25511
That will bring up 34 search hits for 6085, including a couple that might apply:
http://www.digidesign.com/index.cfm?...4&itemid=23959
DAE -6085 errors with an Mbox 2 Pro during playback or record when the AC Adapter is plugged in
Using the AC adapter for the Mbox 2 Pro on a desktop computer can cause these errors. There are only two times the AC adapter should be used:
1) When connecting to a laptop computer.
2) When connecting to an iLink 6-to-4 pin FireWire cable (most common in laptops).
Unplugging the AC adapter and letting the Mbox receive power from the FireWire bus can resolve these errors.
And this one:
Limit the open ended Rec allocation found in the Setups> Preferences > Operations tab > limit to 10 mins
Also could occur if you are using an unsupported drive for record and playback, such as your internal drive or an unsupported type of FireWire drive.
